Gasket material for firewall
Old Apr 9, 2024 | 07:18 AM
Jetmek's Avatar
I need to remove the HVAC units from the firewall. They look like some kind of sponge rubber gaskets were used. Are they available new or what should i use as a substitute? Thnx
Old Apr 9, 2024 | 07:35 AM
I'd use self-adhesive foam tape available at the hardware store.
https://www.homedepot.com/p/Frost-Ki...534H/202262324
Old Apr 9, 2024 | 07:49 AM
FStanley's Avatar
https://www.summitracing.com/parts/o...UaAr9CEALw_wcB
Old Apr 9, 2024 | 07:56 AM
Jetmek's Avatar
Awesome ! Thanks!
Old Apr 9, 2024 | 08:00 AM
Jetmek's Avatar
those look like all A body applications
Old Apr 9, 2024 | 12:49 PM
Which is all you are going to find from sources like Summit.
Old Apr 9, 2024 | 12:59 PM
Jetmek's Avatar
MSC has sheets of 1/4” open cell neoprene. Looks like i gotta make my own
Old Apr 9, 2024 | 07:23 PM
VC455's Avatar
Barely Registered
Open cell is not waterproof. Use closed cell.
Neoprene will eventually take a set, oxidize, and deteriorate (the way the factory gasket did).
Because of that, I experimented with using closed cell silicone foam from McMaster-Carr during an A/C rebuild 15 years ago. It still has flexibility.
Old Apr 10, 2024 | 03:09 AM
Exactly what I did as well. Also got mine from McMaster Carr.
maineolds
Jul 17, 2021 03:47 PM
Oldssupreme
Jul 27, 2016 03:56 AM
fatgroundhog
Jun 14, 2015 03:04 PM
spyke
Mar 28, 2013 08:13 PM
Joel
Mar 7, 2011 10:45 AM
