- Non-traditional center cap on SS wheels
- Matching spare
- My Rim Choice Pics + Tire Size recomendation question
- '76 Cutlass Supreme- Tire Size Options?
- 1964 Cutlass Tire/Wheel Size Fitment
- '68 442 tire size options
- Wheel advice
- Classic Centerline Auto Drags
- Changing the Rim/Barrell of a Wheel
- Wheel size help
- Looking to check if this A.R. SSI style wheel is correct
- ‘69 14x6 SSII beauty ring question
- wheel size for 75 cutlass
- "Oldsmobile F-85, Jetfire and Cutlass Wheel Cover Identification Needed"...
- Wheel help
- Tire Slips on rim
- Wheel help
- Rally Wheel Center Cap Loose
- Wheels size
- After disc brake conversion, original wheels won’t fit.
- Before and After
- 1976-1977 15" wheel trim rings?
- Bolt pattern 66 cutlass
- 69 Cutlass S convertible tires and wheels
- speaking of tires
- BF Radial TA verse Cooper Cobra
- 15x8 & 15x10 SS1 wheels on 66-67 Cutlass/442
- Vavle stems '66 toronado
- Lugs size
- 75 Hurst Olds - proper replacement tires
- Hurst wheel 15x7
- Tire size question for a 76 Cutlass
- Spare & Different size tires
- SSII correct lug nuts
- Running 14” and 15” wheels at the same time.
- 17” white letter tires???
- Brake caliper clearance
- 66 cutlass tire size?
- Coker Redline Wide Ovals Installed
- Wheel ID
- ID old cragar? wheel
- Will it or won’t it?
- 1970 442 Firestone Wide Oval Sup-R-Belt Tire
- Paint and spacers for Rallye II wheels
- Recommendations on SSI rims
- How flush to rim do beauty rings go?
- Mtt 3455 Mickey Thompson 295 65r15
- Hoosier tires
- Repro Goodyear Polyglas GT tires?
- Coker Says I Can
- 17's maybe?
- Directional Stock steal wheels?
- Steel Wheel Paint
- 15" wheel and tire options
- 17"on Cragars on 72 CS
- 65 442 Tire Opinion
- 1967 dog dish hub caps
- 17" tire choices - any particular street favorites?
- Redline Tires - Diamond Backs
- BFG radial T/A white lettering
- Candy Gold Powdercoated Rims
- Cadillac Hub Caps
- SS II/III Trapezoid trims
- Powder coating SSIII wheels?
- 1970 442 Original Spare?
- Will these rims/tires fit?
- New Shoes! (A Poll)
- SSII trim rings like Chevrolet ones?
- Touch up paint 72 H/O gold SSIIs
- Backspacing
- SS III Wheels on a 69
- Calling all cars!! 20 in wheels need help
- 71 cutlass 15' rally wheels fit?
- Hurst Dazzler wheels
- 78 Oldsmobile delta
- New Centerline Auto drag 2.0
- SS3 Trim Ring Depth/Size
- Cragar SS on a 76
- Rally rims
- SSI wheels and rust
- Wheel Help for 1962 F85
- Tire sizes 65 Cutlass
- '69 SSII original spare?
- Looking for wheels for 1982 Olds Ninety Eight Regency
- Wheels
- Street and Strip tires
- What are the odds trying to balance 14X7 wheels & tires
- Drag radials and wheels
- 15x7 w/ 275/60 and 245/60
- Reproduction Tires - What Are Your Thoughts?
- 78 delta 88
- Tire Size
- Stock Wheel Spacing on 62 Cutlass
- 65 cutlass rims
- Opinions on Hankook tires
- Tire Size for '87 Cutlass Ciera
- 66 Cutlass
- Street Lite "442" center caps
- 295/50/15 rear, what 195/??/15 looks best on front
- 15x10 with 7.5bs
- SSII wheels
- 1954 Olds Super 88 Rear Tires and rims
- What are these?
- Rim ID
- New Rim/Tires
- Decoding SSll wheels
- thoughts on the right tires on a bone stock 14x7 1970 Rallye 350 ?
- 66 cutlass 14 tire size
- 275 60 15 on 10”
- Proper load index for my 1971 Olds 98
- Wheel ID from numbers stamped
- Milestar tires
- Need help identificate these wheels
- Wheel Advice 15 or go to 17?
- 15x8 rims advice please
- Custom SSII wheels?
- Homework question
- 1973 Cutlass: 14x8 front wheel/tire clearance?
- 15" wheel for Cutlass
- 65 J88 lug thread
- 1972 Wheel options
- Need help asap please on these wheels
- 14 x 6 SS3 ??
- 1979 Hurst Olds - 1980 442 Lug Nuts?????
- Super Stick I wheel restoration
- Best glue for wheel emblems
- 76 Supreme Widest Tire/ Wheel Combination
- 61 88 needs new wheels after disc conversion
- 68-72 wheel cap bolts
- 1967 SS1 rims
- Correct tire pressure?
- SS I rims
- 245 60r14
- Issue with new tires from coker
- SS1 Differences
- Wheel descriptions
- 1969 Cutlass wheels and tires.
- New guy trying to find tires for 68 Delta Custom
- 15 inch SS 1's, 2's, or 3's?
- Michelin 255 & 285
- Cragar 61C 15x8 - offset for 1970 442?
- New shoes for ‘65
- SS1 lug nuts - 2 sizes?
- 14 inch OEM rim "junk" because of leak?
- Need new tires on '72 Cutlass on stock 14" wheels
- 1970-1972 Dog Dish steel rims
- 85 442 gbody
- 1964 full size 14" tires
- 15x7 vs 15x8
- I need an honest opinion
- Olds Delta 88 Convertible - need help
- Valve stem size ?
- Some new tires for the 442!
- Tire size
- 75 Cutlass Tire size
- Possible Wheels for my CS
- Will 245/55R18 fit a 72 Cutlass?
- Creaking SS1 trim rings
- Date code of wheel 1970
- Wheel play
- SSI Center Caps
- 65 Cutlass 245/60 r15
- 1970 Cutlass Supreme Tire Sizes
- What do you call and where can you get the silver whoosamawhatsits on 70's 14 in rims
- Wheel stud shoulder knurl sizes
- circle racing ssii olds wheels
- 1965 Cutlass Tire Fitment
- 15" x 8" Chrome SSII w/Bolt in caps
- Coker tire, Firestone wide oval radials
- 15 inch trim rings
- New to me rims
- Wheel size
- 17" wheels
- 71 CS Wheel Alignment
- will this General tire fit '69 Cutlass?
- SSII lughole repair
- Radial Tires
- New Wheels for 71 Supreme
- 24 inch Dub Ballers
- 17" superstock 2 wheels
- Maxxis tires any good?
- Anyone know if these will fit my new to me 15 x 7 SS ll / lll Olds rally wheels ?
- Tire size
- Looking for 1964 442 stock wheels.
- 5.29 backspacing on front and rear
- What year(s) were these made?
- Identifying 1930’s hub cap inserts ???
- Help idenity 15" Rally Wheels
- SSIII wheel? Will disc brakes fit?
- Stock tires size for a 75 olds
- 1965 442 wheels
- 17" Chrome Super Stock II Rims
- 1970 Oldsmobile cutlass Rallye 350
- Smaller/Lighter Spare Wheel and Jack Options?
- Staggered wheels on 1976 old's 98
- Where to find correct type white walls for ...
- Wheel Alignment
- Tire size
- Increasing wheels from 15" to 16"
- correct Argent paint for 68 Super Stock II wheels.
- what looks better
- Will these fit?
- Would 15 X 12 inch Cragars fit 72 442 rear?
- Tips to quiet fake wire wheels?
- 15x8 woes
- Daily drive slicks ?
- chrome ss2 wheels
- 345/30/19 on a cutlass (pro-touring thread)
- Mickey Thompson Sportsman series
- Buying used wheels
- 69 442 barn find! :) 225 75r14 or 235 60r14?
- 1968 Supreme Wheels/Tires
- FULL SIZE SPARES - I'm all in
- Installing the five “trapezoid” chrome rings in SSII rims
- What are they worth! ?
- For Sale "Wheel Set" Quantity
- 3.5” backspacing for Delmont 88?
- recommendation for wheels on Scarebird conversion
- 1970 aftermarket wheel question
- M/T Street R vs SS
- Olds wheel?
- SSI rims correct for a 68 442?
- 1965 442 Spare Tire Hold Down
- Correct lug nuts for SSIV Wheels
- Wheel studd
- 1966 88/98/Starfire does wider in back help?
- '69 H/O Original Spare Tire - Mount or Save?
- 1977 Oldsmobile n98 wheels
- Afermarket SS inserts into original SSIV center caps
- 255/275 tire combo
- Need White Wall Tires-85 Delta 88 Royale 4dr
- Wheel Caps
- 1965 442 tires
- 15x7 SSII SSIII deep trim rings
- Will 10" wide rims fit on the back of a 1970 Cutlass S?
- 15x4 or 15x7 Fronts - 72 442
- Jegs SSR Star
- will these fit
- What rims am I looking for?
- 235-60-14
- Wheels back from Powder Coating
- Will these fit?
- 65 Cutlass Muscle Car Look or Pro Touring Look
- fitment of 245 60 15 tires on 15x7 rim
- Backspace for.......
- Could this be the original spare?
- Wheel numbers decoded please
- Wheels and tires for 1970 442 (14x6 vs 14x7 vs 15x7)
- 15X7 SS III and 14X7 SS III
