Tire sizes 65 Cutlass
Hi,
I have a 65 Cutlass and looking at going to 15" tires and wanted to know if any issues running BFG Radial TA 275 60 in the rear stock width axle and 7 maybe 8 inch rims. Will I need to clearance anything as seen a few cars with that size in the rear..
Second question what is everyone running in the fronts 235 70's work out as the same height, but wonder if the widths will cause a problem or would 215 75 be a better option?
Thanks for any input
Regards,
Jim
Regards,
Jim
I have run 275/60-15s on a 65 442. They will fit on a GM 15x7 Steel wheel or any 15x7 with zero offset. Had to lightly massage inner wheel house with a couple wacks from a 5 lb. mall but no rolling of anything or any other rubbing.
Stock tires on a 65 were 7.35 x 14, which were just about 26" O.D.
7.75 x 14 tires were optional and had a 26.7" O.D.
235/70-15s are about 28" O.D. and might pose a problem at the front.
235/60-15s are just about the same O.D. as the original 7.35 x 14 tires.
Hi,
Yes I know both tires are 28" looks like both 235 60 or 70 are 9.3 wide, so wonder if the 70's would fit the front, I've seen 215 75 r15 on a 65 which is 27.7 tall x 8.5 wide, which are close.
The idea is having to keep only 1 spare and it would be nice both front and rear being the same height.
All of those running 275's out back what are you running up front?
Regards,
Jim
Regards,
Jim
For a trial fit I put 245/60r14's on my car when I first got it, had saggy springs.
It looked good until I made a sharp turn and pealed the inside of the wheel well molding, luckily I was able to massage it back in shape.
The way the fenders are shaped there isn't a lot of room for a wide front tire,, I had heard anything over a 235/60r15 up front might rub,, so hence the thinking of using a 235/70 r15 as both are the same width (9.3") vs 245/60r15 which is 9.6 wide.
Regards,
Jim
it looks a little different now with a 20” in the back and 18” up front, and a little bit of a drop. Not every one’s cup of tea I know...
