Click Here
Tire sizes 65 Cutlass
Old Mar 7, 2021 | 05:45 PM
jmos4's Avatar
Hi,
I have a 65 Cutlass and looking at going to 15" tires and wanted to know if any issues running BFG Radial TA 275 60 in the rear stock width axle and 7 maybe 8 inch rims. Will I need to clearance anything as seen a few cars with that size in the rear..
Second question what is everyone running in the fronts 235 70's work out as the same height, but wonder if the widths will cause a problem or would 215 75 be a better option?
Thanks for any input
Regards,
Jim
Old Mar 7, 2021 | 06:00 PM
66SportCoupe's Avatar
I have run 275/60-15s on a 65 442. They will fit on a GM 15x7 Steel wheel or any 15x7 with zero offset. Had to lightly massage inner wheel house with a couple wacks from a 5 lb. mall but no rolling of anything or any other rubbing.
Old Mar 8, 2021 | 05:07 AM
Stock tires on a 65 were 7.35 x 14, which were just about 26" O.D.
7.75 x 14 tires were optional and had a 26.7" O.D.
235/70-15s are about 28" O.D. and might pose a problem at the front.
235/60-15s are just about the same O.D. as the original 7.35 x 14 tires.
Old Mar 8, 2021 | 02:53 PM
jmos4's Avatar
Hi,
Yes I know both tires are 28" looks like both 235 60 or 70 are 9.3 wide, so wonder if the 70's would fit the front, I've seen 215 75 r15 on a 65 which is 27.7 tall x 8.5 wide, which are close.
The idea is having to keep only 1 spare and it would be nice both front and rear being the same height.
All of those running 275's out back what are you running up front?
Regards,
Jim
Old Mar 8, 2021 | 04:35 PM
My front are 225/70-15
Old Mar 9, 2021 | 02:57 PM
jmos4's Avatar
Hi,
Any rubbing issues?
If not does it appear you can go wider?
Could you post some pictures if you have any available?
Thanks again,
Jim
Old Mar 9, 2021 | 03:24 PM
No rubbing issues. I could go wider on the front if i wanted to.
Old Mar 10, 2021 | 03:37 PM
jmos4's Avatar
Makes me wonder if 235/70 R15 might work as .6 taller and .4 wider
Got any pictures?
Regards,
Jim
Old Mar 10, 2021 | 05:06 PM
Here's a picture
Old Mar 10, 2021 | 05:09 PM
oldsmoboogie's Avatar
I am hoping to put 245/60 r15 on the front and 265/60 on the back of my 64. I dont know a lot about tire sizes, but i am curious of why a 70 series up front and a 60 series out back?
Old Mar 10, 2021 | 05:51 PM
jmos4's Avatar
Hi,
For a trial fit I put 245/60r14's on my car when I first got it, had saggy springs.
It looked good until I made a sharp turn and pealed the inside of the wheel well molding, luckily I was able to massage it back in shape.
The way the fenders are shaped there isn't a lot of room for a wide front tire,, I had heard anything over a 235/60r15 up front might rub,, so hence the thinking of using a 235/70 r15 as both are the same width (9.3") vs 245/60r15 which is 9.6 wide.
Regards,
Jim
Old Mar 10, 2021 | 07:04 PM
ijasond's Avatar
Purveyor of Polyurethane
my 66 had 275/60-15 all the way around when I got it. No issues at all.
it looks a little different now with a 20” in the back and 18” up front, and a little bit of a drop. Not every one’s cup of tea I know...
Old Mar 10, 2021 | 07:07 PM
The 65 wheel wells are not even close to the 66 and 67 cars. Shapes are different especially in the rear. Not as round as the later cars.
Old Mar 10, 2021 | 07:29 PM
ijasond's Avatar
my bad. I was thinking 65-66 were same, not 66-67. Just ignore me being irrelevant.
brick
Wheels and Tires
Feb 2, 2021 05:08 AM
jmos4
Wheels and Tires
Jun 25, 2020 08:25 AM
Rolds72
Wheels and Tires
Mar 19, 2012 08:57 AM
nonhog
Nov 12, 2011 10:21 AM
nonhog
May 8, 2008 08:56 AM
