New tires
tire fittament
They will do two things
they will fit & they will look very small.
A 205 60 15 is only 24.7" tall on a 6.5" wide rim so 24.5" tall on a 7" rim.
Good choice for something like a late 70s Starfire but I can not see this tire working well on any A or G body car let alone a B body.
What car are you planning to run these on & what is your rear end ratio?
suggestion
With 3.73 gears & the size of the rear wheel wells on a 72 Cutlass this will give the car much better stance & cruising RPM. Your 26" tall 235 60 15s with 3.73 gears are going to SCREAM RPM on the highway.
235 60 15s will fit just fine on the front.
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
