Click Here
15X7 SS III and 14X7 SS III
Old April 7th, 2019, 05:26 PM
Joe Ralph
72442455's Avatar
Hi all - I am running a set of 4 15X7 SS III’s on my 72 vert - I have no spare tire. I found a 14X7 SS III for free - is it possible to throw a tire on the 14 that would work with the 15’s for spare tire emergency purposes? Thanks in advance for your help - Joe R.
72442455 is offline
Old April 7th, 2019, 06:02 PM
MOTORHEAD
11971four4two's Avatar
[QUOTE=72442455;1165687]Hi all - I am running a set of 4 15X7 SS III’s on my 72 vert - I have no spare tire. I found a 14X7 SS III for free - is it possible to throw a tire on the 14 that would work with the 15’s for spare tire emergency purposes? Thanks in advance for your help - Joe R.[/Q
another matching 15 inch wheel and tire would be better
14 inch tires are crazy expensive and would that be close to the tire height you have now???
11971four4two is online now
Old April 7th, 2019, 06:08 PM
Joe Ralph
72442455's Avatar
I haven’t looked for tires yet - didn’t know if it would even work. Just trying to find something that will hold air - figure it would beat a tow truck *shrug*
72442455 is offline
Old April 7th, 2019, 06:20 PM
MOTORHEAD
So you are getting a tire and rim???
That beats the hell out of nothing
IF you use different height / tall tires the car will lean and if in the rear may cause posi to bind
Old April 7th, 2019, 09:45 PM
Joe Ralph
72442455's Avatar
tires toast - just the rim - what I was trying to ask is - can I buy a tire for the 14 - that would work with the 15s and tires I have on it in an emergency as a spare - I understand that If I run a tractor tire and a caster on either side of my posi or front end I will either tear up my posi or easily make lefts - Hehe - just didn’t know if I could buy some crap tire for the 14 that would match the size of existing 15 set up - that make sense?
72442455 is offline
Old April 8th, 2019, 05:02 AM
I have the same scenario except I do have a spare wheel & tire. My spare is 14x7. I'm completely fine w/ it. If I'm w/in let's say 5-10 miles of an Interstate Exit ramp, or the same distance to the closest service station/tire shop that 14x7 will do the job just fine. I would never run in that condition for ANY extended distance; but, to get to the closest shop it should work fine. Additionally, since I have tubeless radials, I carry a tubeless repair kit. So, as long as there's no sidewall puncture (more like a screw, nail, piece of metal in the tire tread itself) all I'd need would be some compressed air. JS
Vintage Chief is offline
Old April 8th, 2019, 06:53 AM
Joe Ralph
72442455's Avatar
Thank you
72442455 is offline
Old April 8th, 2019, 08:41 AM
What is your tire size? All that matters is that the spare have the same OD as the other tires, but if you have tall 15" tires you may not be able to find a 14" tire that is tall enough. Unless you care about having a SuperStock wheel on the spare, 15" steel wheels are easy to find.
joe_padavano is offline
Old April 8th, 2019, 01:15 PM
Joe Ralph
72442455's Avatar
235/60R15 - yeah I would like super stock - think I have a lead on one - thanks Joe
72442455 is offline
Old April 8th, 2019, 01:23 PM
The internet says 235-60-15 tires are 26.1" tall.
The internet also says 205-75-14 tires are 26.1" tall.
Fun71 is online now
Old April 8th, 2019, 02:00 PM
Joe Ralph
72442455's Avatar
72442455 is offline
Old April 8th, 2019, 02:11 PM
75 W-30 H/O's Avatar
I can't guarantee it's accuracy but this might help...
https://www.discounttiredirect.com/l...ize-calculator
75 W-30 H/O is offline
Old April 8th, 2019, 04:06 PM
MOTORHEAD
Gotcha
As long as the height of the tire is close to same as your 15's it should be "fine"
Be careful if you mix bias ply and radial tires you could have some problems
Bfg
June 1st, 2018 04:50 AM
electraman87
August 10th, 2014 11:36 AM
oldsguybry
Wheels and Tires
February 22nd, 2012 11:09 AM
rocketscientist
August 7th, 2011 01:52 PM
mike623
January 18th, 2011 11:35 AM
Quick Reply: 15X7 SS III and 14X7 SS III
