Click Here
Consider 15" Torq Thrust II Wheels
Old Apr 6, 2019 | 07:27 PM
sjay1989's Avatar
Considering the Torq Wheels. Ideally Im looking for skinnier/taller tires in the front and fatter tires in the rear. What size for the wheels would be ideal? Considering 15x7 in the front and 15x10 in the rear..
Old Apr 6, 2019 | 07:33 PM
Is this for the 71? The link below will give you some ideas and what offset and backspacing works with your size.
https://classicoldsmobile.com/forums...ost-yours.html
Old Apr 6, 2019 | 10:07 PM
dantecl's Avatar
In my '72 Delta 88 I went with 15x7 front and 15x8 rear. Could not fit anything fatter than 245 due to wheel well trim rub.
Old Apr 7, 2019 | 12:10 AM
bry593's Avatar
1968 442 Convertible
My humble opinion, the TT 2 are ubiquitous, and thus are not an interesting wheel. However, TT D look like they should have come stock on a vintage Cutlass.
Old Apr 7, 2019 | 05:38 AM
I actually prefer the TTO (VN309) wheels, which is what I have on my 67 Delta. 15x7 front with 235/70-15 BFGs and 15x8.5 rear with 275/60 BFGs. In this photo the fronts obviously have not been installed yet.
Old Apr 7, 2019 | 05:43 AM
I got distracted and missed typing Cutlass S.
Old Apr 7, 2019 | 08:18 AM
sjay1989's Avatar
Yes, sorry its for the 71. Im having trouble finding decent tires for 14". So looking to move up to 15".
Old Apr 7, 2019 | 07:11 PM
If your going for new wheels and tires, 15's have a better selection than 14's.
Old Apr 7, 2019 | 10:58 PM
bry593's Avatar
Yes, also a great choice that carries the 60’s style perfectly. The primary difference being a more angular spoke.
Old Apr 8, 2019 | 06:47 AM
I had the TTO (VN309) on my Plymouth. Loved that wheel.
Old Apr 8, 2019 | 07:11 AM
70cutty's Avatar
Beer Connoisseur
You can run 15x10 with 5.5" backspacing and 295/50/15 tire with no issues. You could even go bigger on tire depending on your suspension and exhaust. For front 15x7 with 4" backspacing will fit, 15x8 4.5"BS will also fit.
Old Apr 10, 2019 | 05:48 AM
Inline's Avatar
Wow, that looks awesome, both the car and wheels under.
Old Apr 15, 2019 | 11:56 AM
sjay1989's Avatar
Pardon my lack of understanding but what does the backspacing really mean/do for the wheels? My reading online indicates that it referes to the depth of the wheel... and in that case, Im not sure if more or less backspacing is better.
To state it simply, I would like 15" Torq wheels with skinnier tires upfront and wider ones in the rear. I was thinking to go with 15x7 in the front and 15x10?? In the rear
Old Apr 15, 2019 | 02:10 PM
https://www.speedwaymotors.com/the-t...kspacing/30059
The bottom line is that the RWD cars from the 1960s want close to zero OFFSET. That means that the wheel mounting surface is centered relative to the width of the wheel. Backspace is relatively worthless, since it is dependent on TWO variables - the offset and the width of the rim. Unfortunately, it is easy to measure, so that's the number people quote.
Old Apr 20, 2019 | 07:47 AM
sjay1989's Avatar
Looking for a staggered stance. Any idea on the offset for front/back?
Old Apr 20, 2019 | 07:55 AM
They'll work. I personally don't care for the spokes that curve back inward at the outer edge, which is why I got the TTOs, but that's a matter of personal preference. I guess they remind me too much of ingrown hairs.
Perkolator
Wheels and Tires
Jul 26, 2019 10:23 PM
Craig5859
Wheels and Tires
May 10, 2019 08:05 PM
RT PLATE
Wheels and Tires
Sep 21, 2016 06:46 PM
octanejunkie
Wheels and Tires
Sep 24, 2014 06:07 AM
car_designer
Wheels and Tires
Apr 2, 2011 04:51 PM
