Click Here
Backspace for.......
Old May 1, 2019 | 07:03 PM
Craig5859's Avatar
Hi all,
I bought a set of wheels from Jegs recently and sourced tires from tire rack. The tires came then the next morning I got an email from Jegs saying my wheels have been discontinued 👎🏿. They were 18x8 and 18x9....I forget the bs on them. So I now have (2) 235/45/18 and (2) 275/45/18 laying around without wheels.
So, all that to ask what bs do I need to go 18x9.5 in the rear? I have QA1 coilovers all around so adjustability is there up n down wise. Thanks in advance!
Old May 1, 2019 | 09:42 PM
svnt442's Avatar
Originally Posted by Craig5859
Hi all,
Whaaaat car are you working on?!?
Old May 1, 2019 | 10:26 PM
Craig5859's Avatar
Sorry, 71 Cutlass S.
Old May 2, 2019 | 07:49 AM
You want near zero OFFSET. How this translates to backspacing depends on the width of the wheel you select.
Old May 2, 2019 | 01:20 PM
70cutty's Avatar
Beer Connoisseur
For 18x9.5 ideal backspace would be 5.25"
Old May 3, 2019 | 05:00 AM
cdrod's Avatar
Rodney
Craig:
I have 18x9" rims with 5.25" backspacing on the back of my 442 convertible. The tires are 285-40R18 with 1.5" of clearance to the frame rail. I have the body off the frame at the moment so no pics on the car. Here's a link to some pics, scroll forward to post#6 for the pics.
https://classicoldsmobile.com/forums...e-rims-129812/
Rodney
Old May 3, 2019 | 03:30 PM
Craig5859's Avatar
Thank you for the responses! I probably should’ve added I have Wilwood discs all around as well, wouldn’t that affect the offset?
Old May 3, 2019 | 09:10 PM
cdrod's Avatar
Rodney
Craig:
I have 18" Bandit U-109 rims from US Mags and they clear the C5 Vette calipers I have installed on my '72 A-body convertible.
Rodney
Old May 5, 2019 | 07:30 AM
Mr Nick's Avatar
The thickness of the Wilwood rotor is very comparable to the thickness of drums, so nothing to really worry about.
However, you need to be sure the inner face of the spoke doesn't hit the outside face of the caliper. I had that issue with the 17's I originally had on my car, the 18's I have not fit much better.
Old May 5, 2019 | 05:43 PM
Craig5859's Avatar
noted... should I go with 18x8’s on the front or just go with 18x7?
Old May 10, 2019 | 08:05 PM
Mr Nick's Avatar
Either one would fit well up front and the 235/45/18 front tires you already have will work with either size rim as well. I'd suggest getting 18x8 in case you want to go to a wider tire in the future. With the correct backspacing an 8" wide rim will fit easily.
I'm running 255/40/18 on 18x9 up front, and it only kisses the sway bar at full lock backing out of the driveway. My car is lowered about 3" as well.
RT PLATE
Wheels and Tires
Sep 21, 2016 06:46 PM
oldsdriver1218
Wheels and Tires
Mar 6, 2016 08:30 AM
brandon 455
Wheels and Tires
Nov 6, 2013 05:46 AM
gogolf0401
Wheels and Tires
Jul 14, 2011 01:48 PM
car_designer
Wheels and Tires
Apr 2, 2011 04:51 PM
