Click Here
Will these fit?
Old Sep 15, 2019 | 01:39 PM
Hdmike444's Avatar
Will these fit?
Hi
can anyone tell me if these will work on my car without issues, I have disc front and drum rear
im not sure about offset etc.
https://rover.ebay.com/rover/0/0/0?m...2F333310372732
Old Sep 15, 2019 | 05:44 PM
Yes, in fact, I can tell you these will work on your car without issues. See - I said it. I have an innate ability (coupled with my x-ray vision) to read minds.
Old Sep 15, 2019 | 07:21 PM
Charlie Jones's Avatar
Phantom Phixer
Add to that , the ability to read the OP's other posts to determine what model and year car he has .
Old Sep 15, 2019 | 08:05 PM
Hdmike444's Avatar
Ok I’m assuming this got moved, I have a 72 442 convertible with factory front disc and rear drum brakes. I assume these will bolt on with no issue but I figure I’d check here to see if anyone has used them before. Thanks for any help/info
Old Sep 15, 2019 | 08:12 PM
Yes, it got moved as you posted in an unrelated thread. I lost internet when I moved it.
Old Sep 15, 2019 | 09:06 PM
70sgeek's Avatar
'72 Cutlass ragtop
They should fit without issue - 15x8 wheels are typically 4.5" backspace and they clear disc brakes.
My question is I'm used to seeing 15x7 wheels typically with 4" backspace - so at 4.375" I'd think they'll sit farther inside the wheel wells, making them look more recessed than they would if they sat farther out inside them. What size tires do you plan to run?
as an example on my 72 CS ragtop, I run 15x8 wheels with 4.5" BS and 245-60-R15 tires all around (for ease of rotations and spare replacement if I have a blowout). To give the rear a bit of a staggered look, I added 1" aluminum spacers to the rear hubs. Car has a great stance and all wheels still clear the fender wells without issue.
Old Sep 16, 2019 | 03:37 AM
Hdmike444's Avatar
I’m not sure on tire size yet, I was also looking at the 8” rims but was worried about fitment. I’d like to go as wide as possible without having any rubbing issues and also want to keep the same tires all around as well. That is why I was wondering about those wheels, I am not sure what the “best” wheel setup is for my car.
Old Sep 16, 2019 | 07:02 AM
70sgeek's Avatar
'72 Cutlass ragtop
Well 8's will fit with 4.5" bs - that's what many Cutlass owners run all around. And with the right tire size they give the car a wider stance look since they fill the wells out more. 245-60-15 is the widest you can go up front without hitting the fender wells on turns - this also assumes you have good front springs (worn ones will drop and reduce your clearance). 255 series tires can comfortably fit out back on an 8" rim as well (in my case I get pretty much the same rear effect by using the spacers, with added bonuses I mentioned above).
Old Nov 3, 2019 | 05:05 AM
Hdmike444's Avatar
Hi all
i still haven’t bought rims yet and I still want the ss1’s but these torque thrust just came up near me for a decent price new, my question is what does the offset mean for me? Would they work
Old Nov 3, 2019 | 07:23 AM
Originally Posted by Hdmike444
Hi all
Those wheels will not work, the have a 5x4.5 bolt pattern, you need 5x4.75.
Read the following link to understand wheels:
http://www.superstreetonline.com/how...et-rim-sizing/
slantflat
Dec 18, 2015 02:55 PM
TheNewGuy
Brakes/Hydraulic Systems
Jan 6, 2014 08:50 AM
russell7088
32
May 1, 2012 12:15 PM
cheven
Feb 16, 2012 08:44 AM
hunter
Sep 12, 2011 02:50 PM
