Possible disc brake solution 70 88
HELP need these olds gurus to jump in and take a look at this for me and help me understand i may be getting excited but this looks like it may be a solution to us 69-70 b-body solutions for front brakes.
http://www.antechlabs.com/K0GFM/MJC1...Conversion.pdf
i REALLY hope this is true and will work i just get lost reading it ( with kids tryin to talk to me and wife asking questions) but one of you will be able to confirm or bust my bubble HAHA hope not . i will be online all day waiting
again my 70 88 has disc brakes on the front already so let's see what will happen with this
Last edited by russell7088; Dec 12, 2010 at 01:00 PM. Reason: forgot the s behind old haha
Well, my first thought is that Corvette will be 120mm bolt circle while you are 127mm. Rotors can be redrilled though.
The Scarebird conversion for early 60's Olds drums to disc uses a '75 Tbird 127mm rear rotor and off the shelf basic bearings from NAPA to replace the early tapered bearings onto the factory spindles (with their special hub). I would order a 75 T bird rotor and see if the Olds bearings fit into it.
Manufacturers rarely did special sizes, they just picked a size from the Nice or Timken catalog. So, you may need the bearings Scarebird specs too.
scarebird is worthless for these cars i have called them and none of their kits will work on a DISC brake car. i dont have drum spindles to work with and they even said that they have nothing for it anyway just ealy 60's as you stated. also at this point when i cant drive car because of bad rotors i will buy new wheels for it if i have to i have also located a 12 bolt out of an impala that should bolt right in, better for gear changes and also rear drums since they are no longer available. this would also allow me to upgrade to disc brakes on the rear.
thanks for the input
I never recommended scarebird, I simply stated that the 75 T bird rear is 5x5 and that is what they use. If you know that drum and disc spindles are a different diameter, and no off the shelf bearing will fit the difference, then the impala conversion is your easiest solution. .040 in size difference is for you to decide to use.
no problem i have had multiple thread on this and scarebird keeps coming up and those who know the 69-70 issue have been helping on this.. also that conversion link is stating that the 69-82 corvette disc will work with this spindle
so i dont have the knowledge to read the article and know what the diameters of the bearing and all that is. if you know all of these your help is greatly appreciated.
thank brian
thank brian
I've posted this before. Unfortunately, I don't own a 67-70 full size with disks, or I'd try this myself. The 63-70 cars (except the J88) use the same inner and outer front wheel bearings as the 71-76 cars. The rotors for the 71-76 cars are still available and have the correct 5 x 5" bolt circle. I do not know if the diameter, thickness, or rotor offset from the wheel mounting surface is the same as on the earlier rotors, however. Centric P/N 120.66000 is available from RockAuto for under $50 each.
the bolt pattern issue is correct but im at the point that i will change bolt patterns so i can drive my car without problems.
the 71-76 wont work because of the off set on the rotor, which is why the article that i posted caught my attention the owner has a b body chevy impala which has the same issues as the delta 88 and 98 so my thoughts are that this will help us also, i might just go buy the parts and check everything out i thought someone may have more info on the dimensions of the 69-70 rotor to compare this with.
Joe thank you again for posting and all your info you have help me alot since ive been on the forum, we r not to far from each other gonna have to make a day trip out of it and come say hi!!!
How far off is the offset? The rotor I posted above has a height of 4.88". There's another rotor that uses the same bearings and bolt circle, from a 1988 C1500 pickup with F44 HD brake option that only has a 4.51" height:
joe would that be a measurement from the back surface of the rotor to the front mounting surface where the wheel would bolt up i have a rotor off a 70 88 that i can measure. i will look at these rotors tomorrow when i go back to napa and compare better
again thanks joe maybe i should bring you the car and pay ya to look into it for me, just dont know enough myself to just start pulling apart !!!!
Do not understand it but this is what i found in my shopmanual.
Wheel cylinderbore 2-15/16"
Linings length 5-3/8"
thickness 7/16"
Disc diam. .965"
lateral runout .004"
parallelisme .0005"
Disk thickness max 1.250"
min 1.215"
I also have a front disc setup on my 69" 88, and need in the futere also a solution on this.
If nothing works i was looking for this http://www.summitracing.com/parts/SSB-A129-13/?rtype=10
from summit, i do not know if someone having experience with it.
It is expensive, and i do not need all the parts, but í am also unable to find drum spindels becouse i live in the Netherlands.
So if it works and it is easy to mount or adapt let me know.
thickness 7/16"
Disc diam. .965"
parallelisme .0005"
min 1.215"
well the drum spindles are not that easy to find here either not just the netherlands so dont feel bad about that. i did take a front hub assembly to a very knowledgable vette guy i know and we compared the two hubs and it appears that it may work, i gotta find some vette hubs to try this gotta locate some used ones instead of buying new ones right now. the rotors are dam near the same, bearings are the same also. The only thing not sure of yet is where will the rotor sit once mounted compared to the caliper, then if the caliper is off i will then try to get the vette caliper to bolt on, gotta compare the two side by side
Well, if you CAN find a set, there's one more rotor you can try. The Chevy Astro Van with AWD used a separate rotor with the 5 x 5" bolt circle. It is the correct diameter and thickness as the D88 rotors. Again the only question is offset of the rotor relative to the spindle, but with a separate rotor and hub you have some flexibility to mount it front or back. You may need to have a couple of centering rings machined if the pilot hole isn't the right diameter to match the hub. Try this one:
let us know,
i took of my spindels and clean/ respraid them but was a big pain ...... to take those off.
and where is the differense between the disc and drumbrake spindel?
On picture they look almost the same. compared to the other thread with the scarebird set.
And does anyone know what bearing original used on the discbrake? could'nt vind the numbers.
Need the numbers of the front and back and bearing and "centercup"
and does anyone have more data about the original disc/ rotor?
So if anyone having the factory specs, it would be usefull
I also think that the same "69" number/ rotor should be made fore other cars.
http://www.pozziracing.com/brakes.ht..._brake_spindle
I don't believe the other 69-70 full size car rotors are the same. When I was selling the disc brake setup off my 69 Delta 88 that I parted out, I was looking for info on the rotors because mine were bad. I found out that someone is reproducing the rotors for 69-70 full size Pontiacs but all the info I found says each division used there own spindles and rotors. Now, please don't hold me to this, I don't know how true any of this is. I'm only offering this as helpful information. I know the Pontiac rotors were on ebay. Good luck.
Could be, but they shared engine's so why not disk/rotor's and spindels?
My first gues is a buick or pontiac of the same age.
As refer to my question on fabrik number of the brackdisc.
Is it not mentioned in the parts list of the dealers? i gues they could order a new set of disc's.
If we have propper demensions and numbers of the original it is easier to vind a solution.
second, Russel are the rear drumbrake shoes also not available ?
question nr 2,
is there a difference between the 1968 1969 and 1970 brakepad?
http://www.autopartswarehouse.com/de...uSHFIcA=&gan=1
and frontdisc setup?
These are 1967-68 pads:
These are 1969-70 pads (actually, they fit 1969-76):
The link you posted is for the -00520 pads, which are correct for your car.
Now i am curieus, how hard can it be and are people willing to trie helping with this.
As first, drumbrakespindels are differend than disk brake,
What kan be done to this to mount those kits on oure stock discbrake spindel.
where is the huge difference it can't be done? There are so many stories and data.
So i post my diskspindel just painted and one foto i found on the net.
( jep advertised with scarebird)
Uploaded with ImageShack.us
The reason i forward this thread, i live in the netherlands.
And can't return parts i order when it doesn't fit.
And with a few years i need new disk's to
and a link to a just conferted drum brake olds.
http://forums.aaca.org/f138/disc-bra...-a-285094.html
This weekend I am going to measure one of the rotors from the 69' 88 with my caliper. I will take as many measurement as I can. I am very curious to know the thickness now.
Ed
6/5
need to get socket to remove the nut. Mine was small, looks like its 1-1/4" to get out, I had 1". will take care of it next weekend.
Ed
6/5
1969 - 1970 olds full size front rotors
I have indicated on various responses to people all over Classic Oldsmobile
that I HAVE some (not many) N.O.S. Front Rotors for the 1969 - 1970 OLDS FULL SIZE application ------ it is all by itself on Planet Earth ------ and VERY OBSOLETE ----- no Centric Rotor will do with any modification..............
Best to call me -- Craig -- 516 - 485 - 1935....New York.
Mocephus
Oct 1, 2021 09:45 AM
DJS70cutlass
Brakes/Hydraulic Systems
Jun 9, 2014 08:44 AM
