Click Here
Wheels and tires for 1970 442 (14x6 vs 14x7 vs 15x7)
Old April 18th, 2019, 12:13 PM
doneugene's Avatar
Hello,
I have a 1970 442 I am restoring.
I have a lead on some 14x6 rally wheels. I understand this car would have come with 14x7 rally wheels. Do you think there is enough difference to worry about it? I would think for purist restoration I should go 14x7 but I personally am not that concerned. Should I wait for some 14x7's to come up? As well, if I am not going pure stock...ie 14x7, should I go 15x7??
Thoughts?
Thank you!! Don
doneugene is offline
Old April 18th, 2019, 01:02 PM
Pat
patshotrods's Avatar
Don,
Being a 442 I would go with the 14"x7" SSII Wheels. That is what I put on my 1973 Oldsmobile Cutlass Supreme. Also the 14"x6" SSIII Wheels have a Snap-On Center Cap that sticks out further than the 14"x7" SSII Wheels with a Bolt-On Center Cap.
patshotrods is offline
Old April 18th, 2019, 01:09 PM
15" wheels have a better following for tire sizes, 14's are extremely limited.
oldcutlass is online now
Old April 18th, 2019, 01:51 PM
Personally, I would skip on the 14" wheels unless you are wanting a "period correct" restoration. If you are going for that, be aware that the early 14x6 wheels (late 60s) have bolt on center caps whereas the later (80s G-Body days?) have snap on center caps.
Below are pics of my old setup (14x7 SSIII wheels, bolt on center caps, 245-60-14 tires) and the new setup (15x7 SSIII wheels, snap-on center caps, 245-60-15 tires).
As you can see, the differences are subtle and most folks won't be able to tell the difference.
https://classicoldsmobile.com/forums...ost-yours.html
Old 14" wheels / tires vs. new 15" wheels / tires.
Fun71 is online now
Old April 18th, 2019, 04:34 PM
doneugene's Avatar
Thank you all for the insight and advice! Great to have a resource like this for research and comparisons such as wheel size. The side by side photos of the 14 vs 15 is great for perpective.
Much appreciated!!
Don
Old April 18th, 2019, 04:36 PM
mrolds69's Avatar
You should state your location. I don't know how much of a purist you are. 1970 SSII wheels should have bolt on center caps. W/o looking, I'm pretty sure 1968-69 SS11 wheels are 14x 6 and have bolt on center caps. Bolt on center cap wheels are pretty easy to spot, vs snap on center cap wheels. If you plan to show the car or points, judges would dock you for that. What you decide to use is up to you. Anyways, there's a lot of those 14x 7's around. I think I have a set or 2 kicking around here (MA) I'd sell. It's possible there's somebody here that's near you has some. In any event, I would pass on the 14x6 and look for at least 14x7's.
mrolds69 is offline
Old April 18th, 2019, 05:36 PM
doneugene's Avatar
Thanks again regarding location and interest in finding wheels from forum members!
I am in Tucson Arizona. My interest has been piqued by the idea of 15" wheels and also 14x7 SSII wheels with bolt on caps.
If anyone has some for sale please let me know.
I have not visited the classified area of this site but feel I should head there next!?
My Best, Don
Old April 18th, 2019, 08:03 PM
Don, there are a lot of Olds Club of Arizona members in the Tucson area. You should consider joining the club as they would be a good local resource for finding a set of wheels, and whatever other parts you may need.
https://azoldsclub.com/
Fun71 is online now
Old April 19th, 2019, 05:16 PM
stevengerard's Avatar
You can also find 15 x 7 bolt-on center cap rims. They were a '73 only option (maybe part of "74) if you want the look of bolt-ons and go up an inch. The extra inch rim also provides a better ride. If yo aren't too worried about it I'd look for the 15 inch snap-ons - those rims are a lot cheaper than the rarer 15 inch bolt-ons
stevengerard is offline
Old October 23rd, 2020, 10:49 PM
Carsick's Avatar
SSll
I have a 442 that I'm building I want it to look correct but am not a big fan of the 14" wheels. Is there an aftermarket ssll?
Carsick is offline
Old October 24th, 2020, 03:04 AM
JohnnyBs68S's Avatar
https://classicoldsmobile.com/forums...wheels-140750/
JohnnyBs68S is offline
Old October 24th, 2020, 06:39 AM
Rodney
cdrod's Avatar
If you're looking for better tire selection using modern tires, here's some links to the US Mag website. They sell a forged aluminum wheel in 17"-28" diameters called the Saber U497 that is a similar style to the SSII Olds wheel, and I've seen some pics with an Olds center cap too. US Mags also sell a similarly styled SSI wheel in 17" & 18" sizes in cast or forged aluminum. These rims will accept the stock Olds SSI center caps with a little modification to the retainers. The cast wheel is less expensive and called the Bandit U109, the forged wheel is called the Bandit U304. Here are the links:
http://us-mags.com/saber-u497-w-5714.htm
http://us-mags.com/bandit-u109-w-3303.htm
http://us-mags.com/bandit-u304-w-1318.htm
cdrod is offline
Old October 29th, 2020, 12:37 AM
Carsick's Avatar
I like the bandits but the ones in the first part take the cake
Carsick is offline
Old September 5th, 2022, 04:48 PM
ericisback's Avatar
Did the 69 Hurst Olds 442 come with 15x7 SSII’s too (code 890)?
ericisback is offline
euroman1959
May 21st, 2018 05:00 PM
hadafew
Wheels and Tires
April 4th, 2017 01:56 PM
dal442
October 7th, 2015 01:08 AM
jpc647
Wheels and Tires
September 24th, 2014 01:49 PM
mv213
June 6th, 2011 01:45 PM
Quick Reply: Wheels and tires for 1970 442 (14x6 vs 14x7 vs 15x7)
