Paint and spacers for Rallye II wheels
What type of paint should I use on my Rallye II wheels? (Thinking argent gray or dark argent). Also, would the rear wheels better fill the wheel wells if I use a wheel spacer (maybe 1 inch?)? Many thanks.
Rally II wheels are Pontiac wheels. I ASSUME you mean SuperStock II. What size tires are you running? If you have 14" wheels, the largest diameter tire that is readily available is 225/70-14, and at about 26.5" outside diameter it's about the same size as the stock tires. If you are running a 60-series tire, it's way too small. You can get repro bias ply tires that are larger, but they are expensive (and bias ply)
Thank you. Yes, you're correct, SS II wheels on a '70 Cutlass Supreme convertible, not stock or #s matching. These wheels are 15" though it came with stock 14s. Currently running 275/60/15s out back on Torq Thrust 8.5" wides, and it fits just right. Wondering if spacers would match the current track/look.
In any case, stock tires for 1970-72 442s were G70x14. Those are 26.82" outside diameter and have an 8.75" section width. 225/70-14s have a 26.40" outside diameter (less than 1/2" smaller - a 1.5% difference) and an 8.86" section width. Yes, 235/70-14s would be a better choice if they still were manufactured. Go back and read the part where I wrote "the largest diameter tire that is readily available is 225/70-14."
78ChevOlds
Feb 9, 2012 06:50 PM
