Click Here
255/275 tire combo
Old Jun 11, 2019 | 05:05 AM
coppertopgmc's Avatar
255/275 tire combo
Anyone running this tire combo? 255/60/15 front 275/60/15 rear. Any rubbing problems on front? SSI wheels.
Old Jun 11, 2019 | 09:10 AM
I think a lot will depend upon the wheel width, wheel backspacing, and vehicle ride height.
On my 70 Supreme with 255-60-15s on front, the tire would rub the fender lip on turns. I have read that some folks had similar issues, and then other folks had no issues. I swapped to 245-60s and no rubbing issues.
The 275-60s on back should be fine with the correct wheel backspacing as the rear fender wells are huge.
Old Jun 11, 2019 | 06:51 PM
Thanks I think I will stay away from the 255/60 and maybe go to the 245/60, maybe put the 255/60 on the rear, just checked my wheels are only 7 inches wide
Old Jun 11, 2019 | 07:32 PM
70sgeek's Avatar
'72 Cutlass ragtop
you could also run 245's all around and put 1" spacers on your rear hubs to push the rear tires out a bit more. You'll benefit from still being to rotate all 4 tires around and won't have to worry about what to do for spare tire...
w-30dreamin
Wheels and Tires
Mar 8, 2017 10:49 AM
Cutlass455
Sep 27, 2015 01:33 PM
76Cutlass_442
Wheels and Tires
Aug 26, 2015 10:04 AM
bulldogs#10
Wheels and Tires
Jul 3, 2015 08:52 AM
Momoney43
Wheels and Tires
Apr 15, 2014 05:49 PM
