Click Here
65 Cutlass Muscle Car Look or Pro Touring Look
Old May 6, 2019 | 04:51 PM
SLWRDE's Avatar
Hey Everyone,
So the time has come to select wheels for my 65 Cutlass and the wife and I have two different ideas. I want a muscle car look (small tires in the front 15x7 and big tires in the back 15x8) while the wife wants the pro touring look (17x8 rims all the way around). The car right now is stock height. If anyone has either of these two setups can you please post some pictures of your ride and what wheel and tire combo size you have and if you lowered the front, back or both and how much. Also if you have/had experience with both setups, which one did you like better and why. Thanks for all of the help.
Old May 6, 2019 | 06:18 PM
therobski's Avatar
I went with GM big car 15x7 steelies and dog dish hub caps, I like the sleeper look....Give you some ideas....
Old May 6, 2019 | 06:23 PM
SLWRDE's Avatar
Thanks Therobski. That’s a beautiful car you have.
Old May 6, 2019 | 08:40 PM
Donolds's Avatar
I went with American Racing Wheels. 17x7 on front and 17x8 on rear. 2 inch drop spindles out front and I think stock springs out back.
Old May 7, 2019 | 04:22 AM
SLWRDE's Avatar
Donald,
Do you have any issues with the tires rubbing? Beautiful car by the way
Old May 7, 2019 | 06:43 AM
sixtyfour's Avatar
Try the olds rally, if you look around their not bad on price and you can make the centers what ever color
Old May 7, 2019 | 11:39 AM
droptopron's Avatar
delete
This is a 70 so its not apples to apples, but I went with staggered 17's. Kind of a middle ground between Musclecar & Pro Touring. 17x7 & 17x8 with 225/55 & 245/50.
I'd also add that with the price of a decent name brand 15" tire these days, you;ll get 17" rims and better tires for the same $$ if not a little less.
Old May 7, 2019 | 01:30 PM
SLWRDE's Avatar
Sixty Four,
Thanks for the info on the Rally Wheels
SLWRDE's Avatar
Ron,
Nice looking 70 442. I really like the blue
Old May 7, 2019 | 03:47 PM
Donolds's Avatar
It will rub hitting driveway dips hard when turning.
215/50x17 front, 235/50x17 rear.
Old May 7, 2019 | 07:49 PM
Big Daddy Spo's Avatar
F70-15's on Hurst Dazzler Rims / Lowered Springs
I went with 15x7 Hurst Rims and original Firestone Bias Ply Redlines in an F70-15 for my car. I used the Summit Racing lowering springs so a little more than an inch all around. The offset on the Hursts' is only 4 1/2" so the stick out a little with the large tires. I do rub when turning sharp, so just have to be careful. The 15x8 Hursts' have the correct 4 3/4" back space, but not sure how they would tuck in the wheel well. Someday I'll get an original set of 14" Hurst rims and Redlines for this car. Best of luck getting what you want, just remember, this is the fun part of the build!
Old May 8, 2019 | 02:56 PM
SLWRDE's Avatar
Nice car. I never thought choosing wheels and tires would be this hard
Old May 9, 2019 | 06:57 AM
droptopron's Avatar
delete
Originally Posted by SLWRDE
Nice car. I never thought choosing wheels and tires who be this hard
Single biggest thing to change the character of a car in a hour or less
Old May 9, 2019 | 07:30 AM
stan 65 cutlass's Avatar
great thread, lots of good ideas here. i like the clean no chrome look on Donolds 65, wheels are nice too
Old May 9, 2019 | 08:36 AM
Some more ideas in here:
https://classicoldsmobile.com/forums...-yours-105914/
Old May 9, 2019 | 04:57 PM
SLWRDE's Avatar
Oldcutlass,
Thanks for the great info. This is what my wife wants to put on the car with a 17x7 in front and a 17x8 in back. It order for both of us to get want we want, would it be better to stick with the 17x8 wheels in the back or go with a 18x8 in the back. I really prefer a bigger wheel/tire in the back. Thanks again for all of the great info.
https://www.summitracing.com/parts/rwa-bc1-776140g
Old May 9, 2019 | 06:59 PM
The issue with bigger wheels is less sidewall cushion for tires. There is just so much OD that will fit in the wheel well.
Old May 10, 2019 | 03:38 AM
SLWRDE's Avatar
After doing some research it looks like the widest I should go in the rear would be either 265 or 275. Does that sound about right.
Old May 19, 2019 | 05:05 AM
Anar40's Avatar
Love this classic look. Where did you get the dog dishes? What are your tires dimensions? Do you have Larger pics?
Thx a lot!
Old May 19, 2019 | 06:13 AM
therobski's Avatar
The dog dishes are 1 year only 64's original to the car, the rears are 235x70x15 the fronts are 205x65x15-a bit to small I'm going to use 1 for a spare and most likely use 205 or maybe a 215x70 in the front. Going to lower the rear another inch soon.
Old May 19, 2019 | 02:45 PM
Anar40's Avatar
Love it
Sharp ride (i've learned a new expression today!)
I really like 'em, i' have to find the same rims, in black! OEM dog dishes should be hard to find and expensive...i'll try to get chromed baby moon or something like that.
I also like the exhaust position, it makes the rear lines thinner and should be a little bit louder from inside. Very nice car! Thanks for infos!
Old May 20, 2019 | 06:20 AM
therobski's Avatar
Those 15x7 GM steelie's came on the Big Cars and are plentiful. In most cases they came from GM in black. As for the dog dish hub caps, different years are easier to fund and a lot less $$$. I chose the exhaust turn downs like the 66-67 Chevelles SS 396 cars. I think GTO's did the same with 2 pipes on each side back in the day.
Old Jun 29, 2019 | 09:55 PM
SLWRDE's Avatar
Donolds,
What is the backspacing on your rims? I purchased the Torque Thrust VN215’s 17x7 with 4” of backspacing for the front and Torque Thrust VN215s 18x8 with 4.5” of backspacing. That is the only backspaces they offered with those rims.
Old Jun 30, 2019 | 10:34 AM
Donolds's Avatar
I will look it up and let you know
Old Jun 30, 2019 | 11:06 AM
SLWRDE's Avatar
Ok thanks for the help
Old Jun 30, 2019 | 01:10 PM
Donolds's Avatar
Could not find paper work. I think I have 17x7 on front and 17x8 on rear. Back spacing appears to be 4-4.5”.
I have about 3/4” space between sidewalk and inner lip on rear. Front only will rub slightly with driveway dip.
215/50R17 on front 235/50R17 Yokohama Avid Envigor tires.
Old Jun 30, 2019 | 01:22 PM
Donolds's Avatar
I think you will be happy with your choice.
Pictures
from last week at Simi Valley Cops and Cruisers Show.
Old Jun 30, 2019 | 01:46 PM
SLWRDE's Avatar
61Bat
Wheels and Tires
Jul 25, 2018 06:32 PM
RocketV8
Wheels and Tires
Jun 16, 2016 05:36 PM
HonestDave
Jun 18, 2015 04:28 AM
Joffroi
Wheels and Tires
21
Aug 14, 2011 07:08 AM
Rallye469
Feb 8, 2008 04:36 AM
