Going to get tires here soon. I'm going to pull the old ones and have the bare rims for a bit to touch up wheel weight spots. I know they're rim covered, but is there an established modern paint for this color anyone use recently?
What did the paint shop tell you? They should be able to convert that color to a modern mix. Unless they didn't and pulled the formulation from their files.
Hurst also put out the service info on the 75 Hurst/Olds with the following paint codes for the wheels (including your Ditzler number)
Rinshed-Mason A-2714
Ditzler 24149
Dupont 43655L
You may have to bring a wheel in and get it color-matched. And THAT, in and of itself is it's own **** show. Color matching for old paint formulations is not an easy process.
Put 3 brush coats on the wheels where the trim gouges. This style trim ring has teeth that dig into the vertical below the level of the wheel weights. I can't do much with the sheen and texture, and these will be behind the rim anyway, but the color is 99% on, it's enough I would repaint the rims in this color no issue. The gouges previously were to bare metal, and I know the rings will put new ones there, but I did what I could.
Excellent idea. I have some Tacoma wheels I need to refurb, and, although the last set I did with 4 cans of Duplicolor Universal Silver (which is a really nice silver), I need to learn to spray for real. This above was me with a brush dabbing.
