Click Here
15x4 or 15x7 Fronts - 72 442
Old May 25, 2019 | 09:15 PM
pettrix's Avatar
Between a 15x4 and a 15x7 front rims on a 72 442 convertible. Which has the better look?
How much handling performance is lost due to going from a 15x7 to a 15x4 rim? Less tire width contact on the ground with the 15x4 tires.
Old May 26, 2019 | 12:44 AM
15 X 7 would look far better, unless you're looking for an '80s-era Pro Stock look. How much handling do you lose with a 15 X 4? Most of it.
Old May 26, 2019 | 01:52 PM
pettrix's Avatar
I kind of figured that might be the case with 15x4 rims. With a 72 convertible weighing 4,000lbs, the narrow 15x4 fronts probably can't handle the weight of the vehicle going through turns, so it will probably plow through the turns. Overwhelming the narrow width tires.
15x4s are good for the straight 1/4 mile track but they probably stink in driving on the street and handling. I even read that braking distance increases with narrower front tires.
Levellord
Wheels and Tires
Nov 19, 2016 06:29 AM
Seff
Wheels and Tires
28
Dec 8, 2012 12:10 AM
bammer
Wheels and Tires
May 14, 2012 08:04 AM
bammer
Wheels and Tires
May 14, 2012 08:01 AM
Jay D
Wheels and Tires
Aug 24, 2011 07:28 PM
