After disc brake conversion, original wheels won’t fit.
So after our disc on the front, the original wheels won’t fit. So I had to go to a gmc 1/2 ton wheel. These won’t take the hubcaps though. What do I do???
The guys who sold you the disc brake, should have a template. You can download and print. Tape of glue on cardboard. And check the rim manufacture.
https://baer.com/Templates.html See video on how to.
How about you tell us the year, model, and WHICH disc brake swap? "Half ton" wheels have a 5 x 5" bolt pattern, so I ASSUME we are not talking about an A-body. Where did the disc brakes come from?
I did a disk brake conversion on my 69 cutlass the caliper brackets wont clear the 14 inch ss 2 rally wheels.It seems all the after market conversion kits are using the same brackets.I called Dessert Valley and was able to get a set of factory original brackets. Problem solved.
67442nut
February 22nd, 2017 12:59 PM
jon69olds
Wheels and Tires
February 11th, 2011 11:57 AM
