Click Here
Wheel help
Old Dec 8, 2021 | 06:02 PM
GN1220's Avatar
Wheel help
Need help identifying these wheels. All 3 are 14x6 but as you can see 2 are deeper than the other. I have no use for them and would like to get them to someone that might need them. Any help is appreciated. And yes they are all GM bolt pattern.
Old Dec 9, 2021 | 11:14 AM
GN1220's Avatar
Any other pics or info I can provide to help? I figured someone here would know what these are for.
Old Dec 9, 2021 | 11:40 AM
There's numbers on the hoop, and the bead, try uploading pictures of them.
Old Dec 9, 2021 | 11:43 AM
GN1220's Avatar
Will do as soon as I get home, thank you.
Old Dec 9, 2021 | 11:53 AM
There should be some info stamped on the backsides of the wheels - that may help ID them.
Old Dec 9, 2021 | 01:17 PM
GN1220's Avatar
Thanks guys. I bought these at pick and pull years ago as I couldn't stand to see them get crushed. I always preferred the full chrome SS1 but 14's are a bit too small these days.
Old Dec 9, 2021 | 03:15 PM
GN1220's Avatar
I could only find wording on one of the deep ones.
Old Dec 9, 2021 | 03:22 PM
GN1220's Avatar
Here is the back, shallow wheel on the right.
Old Jan 12, 2022 | 12:42 PM
GN1220's Avatar
Still looking to identify these wheels.
Old Jan 12, 2022 | 01:16 PM
hurst68olds's Avatar
they are aftermarket:
MAGNUM 500s
by MOTOR WHEEL Corp.
the year of manufacture stamp is after the MADE IN USA stamp, not clearly visible
but something like M4/6, where 6 = 1966 - the M4 or M1 would be MOTOR WHEEL Corp. plant #4 or #1 etc.
Old Jan 12, 2022 | 01:18 PM
Old Jan 12, 2022 | 01:23 PM
here's a 1969 14x7" version - there should also be a month & day stamped on the rear wheel lip somewhere
Old Jan 12, 2022 | 02:12 PM
GN1220's Avatar
Thank you very much! Unfortunately they are in rough condition and probably aren't worth more than use as a hose reel or something. I thought maybe they were GM and belonged on a Cutlass of some type.
scott_442
Oct 22, 2021 12:07 PM
Don R.
Aug 17, 2021 11:12 AM
dragline
May 26, 2020 07:40 AM
1968CutlassSupreme
Wheels and Tires
Jul 16, 2014 05:38 PM
JediMasterWoop
Wheels and Tires
May 13, 2012 07:38 PM
