- 1971 442 wiper motor
- Replacement for a 1962 Fuel Sending Unit???
- Sandalwood Top
- Electro Plating source for restorations
- Anyone have Pics of the Bumper Jack Brackets (72 Cutlass)
- Convertible Top Fitment Issues.
- Have some deadsteering in the steering box
- 1972 Royale Convertable Heater Fan
- 68-72 Condensor for R134a
- A/C Receiver Dryer with XH7 Desiccant
- 55 olds electric fuel and wiper pump?
- wiper motor resauration
- Best A6 Compressor Front Seal
- A6 Compressor Clutch Bearing Removal
- 55 olds washington license plate colors
- 81 A/C compressor
- Carbuerator repair opinions wanted (needed)?
- Cadmium Plating
- wanna build my first engine......a 455
- exhaust options opinions etc
- Identifying Different Power Steering Boxes
- Mini Starter & Clutch Return Spring
- uh-oh
- Need tips for what frontwindow/doors can fit my b-body
- Reproduction dealer name plate
- Part search
- 75 Delta..convt top help
- Oldsmobile flag
- 1971 Olds 98 wont start-ignition lock replacement
- Speedometer Rebuild Help
- PICTURES NEEDED FOR THE 2015 Oldsmobile Calendar !
- Opinion needed on dual exhaust tailpipes.
- Weather seals
- power brake booster
- Exhausted
- Opinions wanted
- AC Drier Question
- Vintage air
- plugs and wires
- 1969 cutlass/442 dash ductwork
- How to remove the wing window/door regulator assemblies in a 1964 Cutlass
- E - brake cable removal
- '70 Driver Side Outside Mirror
- Classic mechanic
- My AC works!
- licence plate bracket
- A huge THANK YOU :D
- Comparable heater ducts?
- Glass
- 69 442 a/c
- 1969 Cutlass Convertible Top Cylinder Issue
- heater box ?
- Washer pump not working
- Replacing the windshield
- Nice to see OLDS at BACK TO THE 50'3 in MN
- Rear end issues!
- H-pipe to driveshaft clearance
- How high is too high?
- Trans cooler fittings mismatch
- POA valve testing and calibration
- Quadrajet throttle linkage info
- Upgrading to dual exhaust - total newb
- retro radio
- What are the correct bolts for 59 88 Steering Box?
- Steering pump spacer
- Convertible top pump
- How to Cap AC Lines
- a 52 olds super 88 too bad it had already been sold
- convertible glass detaching
- Help?
- Washer Fluid Reservoir
- window sealant
- Dremel brush that won't fall apart?
- expansion valve install
- A/c lowers rpm
- Radio Conversion Harnesses
- Convertible top
- Evaporator Core
- Which AC Compressor for 74 Cutlass
- AC Vacuum Hose Routing
- Anyone know what this is? 67 442
- sound proofing rubber
- Exhaust manifold paint
- vintage water cooler / AC tutorial
- edelbrock 1406 how to rebuild/kit questions
- Rubber Window Seal
- building an engine test stand
- Leaking anti-freeze...Help!
- upper ball joint dust boot replacement
- What do you use to clean the windows in your car?
- A/C for 1972 cutlass supreme?
- 1966 Cutlass trunk decals
- Need a new radiator for my 87 442.
- Valve Cover Decal for L69?
- Battery charging during storage ?
- Hood Release cable
- 1969 Delta 88 Fuel Sending Unit
- Convertible top window - plastic vs. glass
- head gaskets thin!
- You can pay me now ...
- Need grommet that holds throttle cable
- Dripping gas and dark color equal uh-oh!
- 1994 Cutlass Supreme Radio Harness
- 67 Toro Headlight Vacuum Check Valve Noise
- A/C Hose Needed!
- Looking for correct fit Firewall Insulation Pad
- Comfortron Delete - Aftermarket Replacement?
- Amp/Speaker Setup Help
- AC Module Cover - removed - put it back?
- 1971 Cutlass S vacuum set up
- '77 Windshield Washer Motor
- htr core and contrl valve work good-now what...no vaccum?
- awesome road sign
- Squeaky blower
- heater core flow
- Anyone use one of these A body stainless fuel tanks?
- Vacuum lines. I know... AGAIN!!
- Missing Pages From My Assembly Manual
- Flux core stainless steel
- Roof Rail Weatherstripping on 72 S HT ?
- Need help - Should I buy this TIG welder?
- Retrosound Radio for 76 Olds CC
- 70-72 Rally fuel gauge without 2 inner rings
- Loose steering
- Need help to understand size on threaded rod
- Help with Holley 750 DP
- Temp AC delete
- Ignition key
- HEI shims and vac advance
- Auto Transporter
- Core Support mounting hole location
- Universal weatherstrip?
- Oldsmobile prints
- replacing the grilles
- Cover Under Steering Column
- Gas Tank Vent Stack
- 67 Vista Roof Rack Same as Cutlass? Need!
- Jack ID
- Lady and the Rocket
- 69 Vista Cruiser Tailights
- hood latch aka sharks tooth
- Can anyone ID this jack hook?
- Help Please: Original "Wet Look" Vinyl from 1967?
- 1975 Delta Royale manually lowered top
- A\C ductwork diagram for behind dash 72 cutlass supreme
- Looking for OLDS Mechanic - Kansas City
- Heater core seal - where to get a new one?
- Firewall pad replacement
- R134 A/C Change. A good thing? Oil Weight?
- Anyone know of a parts source....
- show your unique DIY
- Anyone try to fit Vintage Air Gen IV exact fit kit into a 67 Cutlass?
- k&N filters
- 67 Toro Vaccuum Headlights - Help!
- A/C hose detail 70 442
- test to load photos
- Shift arm tilt column: SPRING
- Time to Replace the Convertible Top- 65
- Holes on the firewall of my 68 442
- Quarter panels
- 1971 Olds Technical Bullletins
- Reinstalling Glass in Vent Window Frame
- Heat works but blows cold?
- No heat!
- Vinly Roof molding clips??????
- Muffler exploded today
- Weatherstripping help
- Automatic Gear Indacator Pointer
- Steering Wheel Removal
- Under dash Bracket
- 1968 Cutlass Vent Window Rubbers
- dial bore gauge.
- Gauges don't work
- Gauges don't work
- 1967 442 AC help
- Heater door spring
- Mirror, mirror, on my car....
- Fan belt routing!
- Rebuild log book
- behind rear seat?
- Wiper motor linkage differences...65/66/67....
- DPT headers for '65
- Fuel Tank Sending Unit
- thoughts or opinions
- Vacuum Advance Chamber Clearance Problem
- Air Cleaner Temperature Sensor Reproduced for 70 Olds?
- OCA nats judging criteria
- GM Sport Mirrors
- Oil bulb burned out
- Replacing A/C Compressor... what else?
- Dynamic 88 water pump and gear box repair
- Barry Weiss/RM@Auburn,IN
- internal memo from Ransom
- oldsmobile service ring
- Car wont start - if it runs on a hot day!
- hose location & routing for my heater controls
- historical document.
- Non-Olds body dent/rust question
- kneeling on hard ground while working on car?
- Old car/gas smell.
- R12 A/C Conversion?
- 1970 442 pace car#2
- oldsmobile bricks
- New set of keys
- Question for Convertible Owners
- Help With Belts - Size
- Ignition Tumbler Removal 71
- 70 black dash
- 1966 Vista Cruiser Exhaust in 1968 Cutlass
- A/C Condenser mount insulators (bushings)
- Exhaust SBO
- A/C Condenser Needed
- Slow power steering
- Removing clock delete plate bezel
- 1953 Olds Super 88 Clock
- 1953 Olds Super 88 Fuel Filter and Gasket
- 1972 Cutlass: Rear window experts out there?
- A/C evaporator box
- MT floor console mounting
- Adding tire pressure sensors
- Custom A/C heater box
- housings in dash for lamps
- 66 442 dome lite / map reader option
- Plastic wheel tub and radiator shroud
- "Loose" tilt wheel column
- '68 Delmont Exhaust system referral
- bad tail light
- The heat stopped blowing and its cold out here.
- Where would you mount a fire extinguisher on a 1972 Cutlass?
- 1968 Cutlas S antenna
- Trunk Release Vacuum - 69 Cutlass
- wiper switch bad
- New Bumper
- Door adjustments
- 66 442 Trunk Release Vacuum Canister & Lock Pin
- Dash Clock replacment
- 68 Cutlass Gear indicator
- Y-72 option heavy duty cooling
- 1972 blower motor repacment
- 69' remote mirror disassemble?
- Lost an Olds friend
- Early Xmas Gift
- Vacuum line help
- Need a radiator!!
- New fuel lines
- Glove Box Lamp Install ?
- steering wheel removal?
- bumper rechrome
- 66 442 gas tank vent
- Square air ducts
