steering wheel removal?
Old Oct 12, 2011 | 09:03 AM
65OldsDelta88SuperRocket's Avatar
Question steering wheel removal?
On my 65 Olds want to remove my steering wheel in efforts to fix my turn signals.
The switch broke and the pieces are inside the steering column.
I will try to get pictures soon
Old Oct 12, 2011 | 09:08 AM
RAMBOW's Avatar
Ben
Do you have your chassis service manual? It should have detailed instructions for removing the horn button/cover w/o damage (wish i had read that part of mine before i tried...)
Otherwise just borrow/rent a steering wheel puller tool from your local autoparts store. Remove the big nut at the hub- install & tighten the puller, and off the wheel will come.
Old Oct 13, 2011 | 11:34 AM
You are right. I took everything off the cap and bolt and I need a puller to get the wheel off.
I assume most old cars like this have that type of locking mechanism?
Old Oct 13, 2011 | 12:07 PM
Oldsmaniac's Avatar
The shaft and wheel are splined and it is a tight fit and that is why a puller is needed. I would suggest you purchase a harmonic balancer puller as it works on steering wheels too.... You will have 2 tools in one and they are pretty inexpensive.
Old Oct 13, 2011 | 02:24 PM
stan 65 cutlass's Avatar
Never had to use one yet, leave the nut on a few threads so it doesnt hit you in the face, wiggle it violently side to side up and down and it usualy pulls right off first time
Old Nov 13, 2011 | 05:46 AM
starfire's Avatar
I've never, ever had that method work (tried it many a time!). If it's a plastic steering wheel you can break or crack it using this method.
at3reg98
Aug 16, 2012 09:43 AM
rroth01
Sep 1, 2011 07:37 AM
ghostrider
Jan 10, 2010 06:10 AM
jdanieljones
Oct 27, 2008 06:19 PM
cola
Dec 8, 2007 05:43 AM
