Removing clock delete plate bezel
Old Mar 20, 2012 | 10:35 PM
yeahbuddy's Avatar
I want to remove my clock delete plate in my 68 Cutlass Supreme to install a tach. Saw the idea in another thread. I see it move side to side when I try to move it from the front. What is the proper way to remove the lens and bezel?
Old Mar 21, 2012 | 02:47 AM
Yellowstatue's Avatar
With the screws out and the wiring disconnected...push it straight from under the dash, back towards the steering wheel...
Old Mar 21, 2012 | 05:00 AM
starfire's Avatar
It's a clock delete, there should be no wiring.
Old Mar 21, 2012 | 11:20 AM
yeahbuddy's Avatar
So basically reach under then dash and push forward. The top part I am able to swing side to side but there is a latch on the bottom that does not release. Is it held in with a screw?
Old Mar 22, 2012 | 05:25 PM
starfire's Avatar
There is no latch. Like Yellowstatue says once you have the two screws out, it just pushes out from behind. You may have to really wiggle it though as the screw heads that hold the clock delete to the bezel want to interfere with the edge of the dash pad. If you don't have an assembly manual, go to www.wildaboutcarsonline.com and sign up for a free membership. Then once you are logged in do this:
Go to "The Library" (top menu), then "Download Factory Published Materials", then "Oldsmobile", then "Assembly Manuals & Inspector's Guides", then "1968", then "1968 Oldsmobile A-body Assembly Manual", then "Section 1.3". You can then see what you are dealing with.
Old Mar 23, 2012 | 09:41 AM
yeahbuddy's Avatar
Thanks for the link! I need to figure out how to reach back there without ripping everything apart.
Old Mar 23, 2012 | 06:19 PM
yeahbuddy's Avatar
Thanks guys. Layed upside down on my bench seat and sqeezed my hand enough to unwind the screw. I wanted to remove the clock delete place to install a (cheap) dash tach. I got this Sunpro Mini Super Tach for $22 shipped. That was my only expense. I think it came out looking good! Will install sometime this week. Thanks again.
Old Mar 24, 2012 | 03:37 AM
The hard part is to get the screws started... If you have small hands and are a Doctor with a lot of patients, then go for it...
88hurstolds
Apr 15, 2014 04:32 PM
D Appeldorn
Oct 19, 2010 11:26 AM
defiant1
Apr 25, 2010 09:03 AM
kjr442
Mar 31, 2010 08:56 AM
squirell
Nov 20, 2009 06:34 PM
