PDA
View Full Version : Other
Pages : 1 2 [3] 4 5 6 7
  1. Gas cap question...
  2. Cruise Control Interchange
  3. Cutlass blowing warm air on passenger side
  4. New Free E-book
  5. Odd thing inside quadrajet?
  6. Replacement radiator core supplier
  7. Dash center speaker
  8. exhaust
  9. 64 cutlass throttle linkage with quadrajet?
  10. Trico Classic Wiper Blades
  11. Not your typical "grocery getter"
  12. "Black Oxide" coatings
  13. Red or black fender well restoration
  14. 1965 VC Wagon/4door power window interchangeability?
  15. 71 Cutlass 350 Compressor Bracket
  16. "Need" list vs. "want" list.
  17. Holly 770 Street Avenger Fuel pressure
  18. Few thoughts and help
  19. 60's SBO HC - GAS?
  20. How does Hood latch pull handle attach?
  21. Best car cover?
  22. Heat control question
  23. Speedometer not working - speedo drive gear
  24. Dr. Olds graphic
  25. Electric fuel pump.
  26. Gauge questions on 76 cutlass
  27. Build sheet question
  28. Can anyone tell me what these are?
  29. disc brakes upgrade vendor question
  30. Regulator-Glass disengagment Low mileage '88 88
  31. Wierd thing spring
  32. Blower motor wheel
  33. Any pics of w-31 carb any1 ?
  34. Tic Toc Tach
  35. Dual Exhaust Upgrade
  36. 67 w30 horns
  37. 54 Olds Aluminum Radiator
  38. Windshield wiper refills 1967 cutlass
  39. Mouse! / Mice!
  40. Help! Bumper bolts question
  41. Penetrant for plastic?
  42. 64 F-85 2-dr. post car rear qtr. glass guide parts needed
  43. 6.5 speakers were should I put them
  44. 63 Stalllin
  45. Tic Toc Tach Repair
  46. Windshield wiper question
  47. missing vacuum hose
  48. Radiator
  49. stalling issue
  50. 1975 Delta 88 Refrigerant suction/discharge A/C hose
  51. 67 Headlight Bezel Reconditioning
  52. 65 Cutlass hood nut fix
  53. Kinked fuel line
  54. 71 Cutlass steering wheel removal
  55. 77 Toro door lock mechanism
  56. Radiator thread adapter sizes for GlowShift temp sensor
  57. 1964 carb fuel line
  58. 64 F-85 gas tanks with filler neck
  59. Help ID distributors
  60. Antenna on the drivers quarter panel from dealer?
  61. Heater core & evaporator advice
  62. headlight conversion question
  63. Cast Iron Damage
  64. '91 Custom Cruiser power mirror jack screws
  65. A/C Vacuum Lines
  66. Reseal Rear Glass 1967 Olds 96 LS 4dr
  67. GM Suisse CKD Assembly 1936-1958
  68. 1964 cutlass body weight
  69. Muffler reccomendations?
  70. Looking for vendor - 66 Cutlass back glass
  71. Emblem restoration?
  72. Tach options?
  73. Shipper to south texas
  74. Stance (Tire size)
  75. Rear spolier
  76. Heater Control Valve
  77. Harrison radiator for 1955 Rocket 88
  78. Hood Springs
  79. 2GC Carburetor Choke question
  80. replacement gas tank
  81. Devastated
  82. Carburetor re-build question
  83. Power Steering Loud Deafining Screeching
  84. 1954 Super 88 generator bracket
  85. 1966 Cutlass Heater Core Parts Recommendation
  86. 1967 heater core replace directions
  87. What parts to buy
  88. Anyone have a compressor restored by Original Air Group?
  89. 1960 Oldsmobile Dynamic 88 Convertible Washer Bottle & Bracket
  90. Olds 98 parts
  91. It's like Christmas today!
  92. POA Valve need to be switched ?
  93. 1971 442 ac heater box
  94. Gas tanks
  95. 67 Olds 442 Exhaust recommendations
  96. Retrofit Radios
  97. I think its thw window regulator???
  98. Looking for lower trime on a 72 rear window cutlass supreme
  99. R4 knocking
  100. Windshield wipers & Washer?
  101. Air Conditioning Recommendations - 1972
  102. 442 Audio
  103. Inner door part. Where does it go?
  104. Convertable top cylinders
  105. 93 Cutlass Cruiser - High Temp When Accelerating
  106. Fuel pump
  107. Grounding Fuel Tank Sending Unit '55 Olds S88
  108. Removing dash heater controls
  109. Trunk carpet
  110. ADDING ELECTRIC FANS - Have a question
  111. 1971 Cutlass bench seat with armrest seat belt bezel
  112. 1971 Oldsmobile cutlass convertible window alignment with felts
  113. 1956 Super 88-wheels
  114. Front / Back Window Sealant
  115. 7045213
  116. 1970 olds 98 cabriolet steeringwheel nut size?
  117. how to remove fuel sending unit
  118. 1980 Cutlass Window Crank
  119. Replacing door locks 72 Cutlass
  120. 1973 Cutlass Supreme ignition stuck, after swapping shifter..
  121. Door locks inoperative 1980 Cutlass
  122. 1962 Oldsmobile Full-size "B" Body Gravel Shield
  123. Fuel tank '65 Vista Cruiser
  124. Delta 88 and Jet Skis
  125. Searching for 1966 Delta 88 Convertible Gear Shift Indicator
  126. A/C not blowing
  127. Muffler Type
  128. AC Drier question
  129. I found this pretty interesting alternative to a tube notcher
  130. Aftermarket gauges
  131. 86 Olds Cutlass trap door is not opening the arm not co
  132. Vacuum diaphragm for air cleaner
  133. Vent window regulator
  134. 96 Olds 88 heater
  135. Heat problem
  136. Stainless trim pieces - 68? 69?
  137. 1962 Ninety Eight bumper bolt
  138. 68 442 Lower Hood Latch Release Rod
  139. '62 molding clip
  140. How do you test a speedometer?
  141. door lock rod from scratch?
  142. Vent window comparables?
  143. OE or OEM Part AC Compressor
  144. AC compressor reseal
  145. Compressor Clutch Not Engaging
  146. Windshield washer pump restoration question
  147. 1993 Oldsmobile 98 AC Compresor Replacement
  148. 1965 heater control unit removal
  149. Heater Core Connections Olds 1956 Rocket 88
  150. Radiator suppliers - who makes the most authentic '70
  151. Putting New Felt Channel in the Vent Window Asm
  152. 49 olds model 98 door handle trouble
  153. Air Conditioning Blues
  154. Walter & Lennertz Oldsmobile
  155. Heater controls,lubrication ??
  156. heating and cooling?
  157. What's the deal with the 77 era high pressure power steering lines?
  158. Edelbrock E-Street 2 EFI?
  159. Another AC question
  160. PO had serviced R 12 system with R 134
  161. 70 Cutlass Radiator Options
  162. External Air Vent blower 1963 dynamic
  163. Trouble shooting AC
  164. Bolt or stud?
  165. Exhaust manifold repair.
  166. Restoration decals
  167. R12 AC work in MN
  168. Rebuilding / Restore wiper motor
  169. Left rear quarter window
  170. AC O ring and schrader valve question 72 cutlass
  171. Window tint color
  172. Vent Window Seals
  173. Refrigerant R12 or R134 ?
  174. Frosted AC parts
  175. Convert leafs to coils
  176. Fuel Filters
  177. Radiator companies
  178. Which oil do i choose?
  179. 1976 455 power steering pump
  180. vacuum cannister connection?
  181. convertible top latch recepticles/guide pins
  182. fixing or upgrading AC
  183. dual quads setup
  184. Correct Jack for 68 442
  185. Drip rail chrome
  186. Proper HANGERS at aft end of Mufflers
  187. Wing window
  188. New 68-69 S/442 wheel well moldings by Fusick
  189. 68/69 passenger side mirror
  190. 1966 Cutlass Vert door alignment details
  191. Looking for replecement radiator
  192. Door strikers
  193. Where are the brakes at???
  194. Something missing...
  195. Vent Window Handle Hole Size
  196. Please help identifying part?
  197. New ragtop owner questions
  198. Window Repair
  199. Need some help identifying hoses, buttons, etc.
  200. Update to power windows,cutlass.
  201. 62 cutlass Alum crossflow rad replacement
  202. 1970 washer bottle options
  203. Rear disc brakes for a Cadillac
  204. ’68 Cutlass hidden wipers
  205. 66 442 tricarb w/ ac ?
  206. Headers motor mounts
  207. Got Gas (water, varnish, etc.) - What Now?
  208. 1965 Carb Question
  209. Weatherstripping
  210. Vehicle Expense/Gas Mileage Tracking Software
  211. SS bolts on exhaust yes or no
  212. 1973 Cutlass Supreme is not getting heat
  213. Painting Letters on OAI Surround
  214. windlace convertible 70 supreme
  215. Jack identification
  216. The name the parts game.
  217. 68 Cutlass / Offset Radiator Core Support?
  218. Chrome shops
  219. '96 Aurora Front Seat Adjuster Rear View Mirror Module
  220. 1959 Radio ???
  221. Vacuum Canister
  222. Gas Gauge off by 1/4 of tank
  223. Have a good alarm system?
  224. Is there a 1969/1970 442 repair manual out there?
  225. fuel pickup sock
  226. Maybe bad gas??
  227. '68 442 Front Hub fitment/X-ref questions
  228. Changing Speedometer mileage
  229. Gas tank vent
  230. Squeaky Noise from the speedo area
  231. BiG servopump leakage problem
  232. Sport mirror internal reinforcement?
  233. Pro6ten AC compressor
  234. trunk hinge
  235. Fuel venting
  236. hood clearance with non oem maniolds
  237. Bumper jack foot plate
  238. 1970 Cutlass Wiper Problem
  239. Help - 1956 Rocket 88 - Window Wiper Vacuum Pump Line Setup??
  240. How many liters Oil is standard on bbo oilpan?
  241. A/C compressor replacement retrofit
  242. vacume hose size
  243. 1970 Olds, vent window ?
  244. 1963 Oldsmobile F85 Cutlass F-85 Convertible
  245. Question about starterswap and details in enginroom
  246. Emission Decal
  247. Copper/Brass Heater Core are absolite
  248. Bonus from a customer
  249. Dissasemble the engine without tranny, question
  250. What Size Seal 72 Cutlass S Rear Glass ?
