Devastated
Old Oct 6, 2017 | 06:16 PM
billmerbach's Avatar
major noob
Devastated
So the other day I was going to release the hood latch on my 73 98 and the release cable came off the latch I das a mini heart attack well trying everything and calling a few people nothing worked I even dropped the sway bar and tried crawling up in the bay with my arm trying to open the latch but the dang nose is so long I was about a foot too short I had to cut a hole in my hood to open it looks like the bushing that held the cable in place came off and wrecked my world
Old Oct 6, 2017 | 06:39 PM
Gary M's Avatar
So you already cut the hood? Did you try using a coat hanger? Sucks if you lost your hood.
Old Oct 6, 2017 | 06:56 PM
major noob
I spent 3 days trying to get her open coat hangers slim jims wire you name it I tried it gotta do what you gotta do I got another hood sourced just need to get up money and go get her
Old Oct 6, 2017 | 07:27 PM
Gary M's Avatar
That sucks
hope you can fabricate a way for it not to happen again.
Old Oct 6, 2017 | 08:45 PM
major noob
I'm gonna get to working on that tomorrow
Old Oct 7, 2017 | 04:28 PM
CRUZN 66's Avatar
Olds Fever
There was no way to get to the latch by removing one of the grilles???
Old Oct 9, 2017 | 08:50 PM
major noob
Nope I'll have to take a video tomorrow and show it's easier that way
Old Oct 10, 2017 | 06:32 PM
coppercutlass's Avatar
Chevy budget Olds powered
Not gonna be a negative slug here but. more creative measures could have been taken. been doing body work for over 10 years and i have done lots to safely open seized latches and what not. dropping the bumper and removing the grilles should have given you enough room to safely get the hood open.
Old Oct 10, 2017 | 07:20 PM
major noob
And again I will say if I had saw a better way I would have I thought about that too and I got down to doing so realized it would t work and did what I had to
Old Oct 10, 2017 | 07:51 PM
Cutting a hood to get it open is the big hammer approach. More critical thinking would have probably paid off and im 100 percent sure of that.
I have had it happen many times in the shop and cutting a hole in the hood isnt an option. Your car has a huge advantage in that you can drop the bumper and many parts to access the latch and probably split the latch in half then grind the remiander from the striker on the hood. Then all you would need is a latch assembly.
On more modern cars like early 2000's impalas its not so simple as you cant really remove the bumper with out the hood being open. I have had to go underneath with long reach carbides and grind the bolts off the latch and cut the cable to open it without causing damage.
1hr grinding off bolts 50 bucks in parts and we did what many shops told that customer they couldnt do.
Old Dec 6, 2017 | 10:10 PM
Gerald Nickels's Avatar
Drop the front bumper and take hood off then the driver fender.
Old Dec 19, 2017 | 06:28 PM
wow
Old Dec 19, 2017 | 07:55 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Looks like Bill has dropped off the radar again.
