Reseal Rear Glass 1967 Olds 96 LS 4dr
Old January 9th, 2018, 10:36 AM
dprestia's Avatar
My rear glass is leaking - big surprise right! ... Glass company doesn't want to nor recommend removing to reseal since the likelihood of breaking the glass is almost certain... Buying new glass does not appear to be an option..
Is breaking the glass really that much of a certainty?
Definitely looking for advise -
Thanks in advance - David
dprestia is offline
Old January 9th, 2018, 10:56 AM
No, breaking the glass is not a certainty. The hardest part of doing the job is removing and reinstalling the trim. You need to find a company that specializes in old cars. It won't be cheap.
oldcutlass is online now
Old January 9th, 2018, 11:28 AM
Cory
dream66's Avatar
Is that trim removal and reinstall different than any other 60's vintage GM car?
dream66 is offline
Old January 9th, 2018, 12:53 PM
dprestia's Avatar
isn't there a tool for this?
isn't it the same clips used for all trim in this gen?... there's a clip tool for this right?
dprestia is offline
Old January 9th, 2018, 01:20 PM
The trim is the same for any other older car, however the pool of people familiar with it is getting smaller.
Old January 9th, 2018, 03:15 PM
RandyS's Avatar
As Eric said, the hardest part is removing the trim. You have to go slow and be very careful or you will at a minimum distort it, or at worst, bend the heck out of it....... don't ask me how I know.........
Once the trim is removed, you can use Weatherstrip Cement to seal around the rim of the window and re-install the trim. When the trim is off is a good time to have it polished. A good polishing shop can take out dings & scratches (or fix anything you may have done when removing it) and polish it up like new.
RandyS is offline
Old January 9th, 2018, 04:03 PM
Oldsmaniac's Avatar
Breaking the glass is no worry at all if you know what you are doing. Perhaps the fear is what they will find once the trim and glass is removed. This area typically rusts thru causing the leak and not necessarily the seal itself. The seal does dry out though for sure.
Oldsmaniac is offline
Old January 10th, 2018, 07:06 AM
^^^THIS. The seal rarely goes bad. Its the rust at the pinchweld that causes the leak. Don't be surprised when you pull the trim off and see something like this.
joe_padavano is offline
My2nd 69 442
April 24th, 2017 02:22 PM
My2nd 69 442
December 10th, 2016 08:49 AM
Junkman
October 8th, 2016 01:49 PM
ThomasAlicea
August 30th, 2014 12:03 AM
fv64olds98
Drivetrain/Differentials
May 10th, 2013 06:47 AM
Quick Reply: Reseal Rear Glass 1967 Olds 96 LS 4dr
