Headers motor mounts
Old Dec 10, 2015 | 04:38 AM
captmark's Avatar
Hi guy I'm restoring my 72 s bought headers on line right side fits fine left. Side hits the motor mount do in need to change motor mount to put header on has any one ran into this problem
Old Dec 10, 2015 | 06:07 AM
First, are you sure you have the correct headers for your engine. SBO and BBO are different. What "on line" headers did you buy?
Second, are the motor mounts old? Often, the rubber will deteriorate and sag (especially if oil has leaked onto them), sometimes causing header fitment problems.
Third, every header manufacturer routes tubes differently, and even repeatability of tube placement from one set to the next from the same manufacturer can vary. It is unfortunately not uncommon to require minor "massaging" of headers to fit.
Old Dec 10, 2015 | 08:06 AM
TripDeuces's Avatar
Yes my header pipe hit the engine mount. I just notched it. I'm using ARH headers with a 2" pipe
The_Jeremiah
May 16, 2019 03:19 PM
joesw31
May 31, 2015 04:17 PM
Nasty455
Mar 20, 2012 04:57 PM
ctrain22
May 20, 2009 11:02 PM
flatoz
Mar 15, 2009 02:03 PM
