Penetrant for plastic?
Old May 22, 2018 | 07:54 AM
Jon442's Avatar
Gearhead
I have a '79 Lincoln that is all original. One of the reverse lights is out, and I went to remove the socket to replace the bulb. I suspect on this car, the socket has never been removed from the tail light housing. So, it's stuck in there tight. I've tried to turn it and tried pushing while I turned it, but no luck. It won't budge. Is there any kind of penetrant, like penetrating oil, that is safe to use on plastic? Otherwise, I'm afraid I'm going to break something getting the socket out of the housing
Old May 22, 2018 | 08:04 AM
OLDSter Ralph's Avatar
I would think some kind of silicone spray that's safe for plastics at an auto parts store.
Old May 22, 2018 | 08:33 AM
^^^This. Use only silicone products. Any petroleum-based products will eventually attack the plastic.
Old May 22, 2018 | 08:47 AM
Jon442's Avatar
Gearhead
So would WD-40 be safe?
Old May 22, 2018 | 09:05 AM
What do you think?
Old May 22, 2018 | 10:16 AM
I've used Simple Green and a toothbrush in the past to clean and then disassemble plastic wiring connectors. It seems to work well.
Old May 22, 2018 | 11:45 AM
Tedd Thompson's Avatar
Try a heat gun or hair dryer that sometimes works. Don't get too aggressive and melt something..... Tedd
Old May 24, 2018 | 07:24 PM
Ozzie's Avatar
Try removing the other backup light socket. Sometime "technique" is important if you've never removed it before. Be sure there is no "lock" that needs to be released. Try the silicone. Try Tedd's suggestion. An extension of it would be to SLIGHTLY heat the housing while cooling the socket if you can. Another possibility would be to GENTLY tap on the socket. Also you could try one of the Lincoln or Ford forums. Someone else may have already had the same problem.
NWG-body
Oct 30, 2004 07:30 PM
emarkay
Aug 9, 2004 08:12 AM
CTWalneck
Jan 12, 2004 12:32 PM
CTWalneck
Jan 12, 2004 12:30 PM
<CTWalneck>
Jan 12, 2004 12:05 PM
