Heater controls,lubrication ??
Old August 10th, 2016, 07:49 PM
GCH
GCH's Avatar
Hi,just wonder if anybody sprayed a little lubrication in the "slots"
on the push buttons (???) on the heater control panel ?
My "push buttons" are a little hard to push in.My defroster does not work at all,only
heat on the floor.But this maybe is a vacum problem.Would be nice to have the defroster working.
Dynamic 88-65.(sorry about wrong words )
GCH is online now
Old August 11th, 2016, 07:00 AM
Originally Posted by GCH
Hi,just wonder if anybody sprayed a little lubrication in the "slots" on the push buttons (???) on the heater control panel ?
I wouldn't do that.
You need to remove the heater control unit from the car, take it apart, clean it, and re-grease it using a white lithium grease, or some other good grease of your choice.
MDchanic is offline
Old August 11th, 2016, 07:50 AM
GCH
GCH's Avatar
Ok thanks,better to wait,should try to see why not the defroster works and wich vacum clock this is.Can see one facing backwards and one facing to left under the dash.
GCH is online now
Old August 11th, 2016, 07:53 AM
They are simple devices, and work SO much better when cleaned and re-lubricated.
MDchanic is offline
Old August 11th, 2016, 07:59 AM
GCH
GCH's Avatar
Yes,checked a picture now it says that the "diaphfragm" facing left should be for the defroster.
GCH is online now
Old August 11th, 2016, 08:08 AM
You can remove the original vacuum hose from the diaphragm, press on a new length of hose, and suck on it with your mouth to see whether the diaphragm moves the flapper, and whether it leaks air.
MDchanic is offline
Old August 19th, 2016, 07:27 AM
GCH
GCH's Avatar
Tried this but it could not feel any air from the defroster (was hard)
When fan is on max i could feel a little air from driver side defroster but most of the air flows at the floor.Maybe the flapper has stuck.
GCH is online now
Old August 19th, 2016, 07:37 AM
When you do that, you should be able to hear the door moving, with the engine and blower off.
You should also feel the diaphragm pull up against the stop, and not have any more air moving - if there is no stop, and you can just keep pulling in air, then there is a hole in the diaphragm.
MDchanic is offline
Old August 19th, 2016, 07:50 AM
GCH
GCH's Avatar
Ok thanks,i should try it one more time.
GCH is online now
Old October 2nd, 2016, 10:40 AM
GCH
GCH's Avatar
I wouldn't do that.
Hi again ,the defroster seems to work better now when i used the heater a little bit more.
But i think the whole heater control unit must be removed and cleaned and
lubricated.Have looked in the chassies manual but not found the easiest
way to remove it from the dash.
Any tip about this are great.
/Glenn.
GCH is online now
Old October 2nd, 2016, 06:26 PM
Unfortunately, I am not familiar with the '65s, so I can't give you good guidance.
I'm sure another member can, though.
MDchanic is offline
Old May 1st, 2017, 10:23 AM
GCH
GCH's Avatar
Any tip where to buy a new diaphragm , one of my diaphragms are defect. Guess some vacum leak in the heater control unit,can feel i little vacum in the hose but to poor to open the diaphragm who still works.
Has a vacum line direct from the canister in the engine compartment connected to the heater valve on engine and the diaphragm that still works ( facing backwards).
The trap door who was connected to the defect diaphragm are locked in open mode
now.
GCH is online now
pcard
Tech Editor's Desk
24
August 4th, 2020 11:06 AM
leroycjr
20
January 10th, 2018 03:48 PM
bobmobile
April 18th, 2015 08:51 AM
The_German
July 3rd, 2013 08:09 AM
Texas442
November 27th, 2009 05:01 PM
Quick Reply: Heater controls,lubrication ??
