Vacuum diaphragm for air cleaner
Old Jan 9, 2017 | 05:38 PM
Nihayde's Avatar
Evening folks
On my 70 442 I had to replace my vacuum diaphragm as it would not actuate with a vacuum. The one that came with my car had a bend in the metal stick that presses on the valve in the air cleaner to allow hot air into the engine.
On the new one the metal stick is straight. I noticed on the valve in the air cleaner there is a hole that allows the metal stick to fit into it if I bend the stick.
My question what is the proper setup? I consulted my engine and assembly manuals and see no reference to how to setup.
Thanks in advance.
Old Jan 9, 2017 | 06:36 PM
2blu442's Avatar
Just to clarify, this is the valve in the snorkel of the air cleaner housing correct? John
Old Jan 9, 2017 | 06:38 PM
Nihayde's Avatar
Yes it is
Old Jan 9, 2017 | 07:01 PM
2blu442's Avatar
OK, if someone doesn't post the answer first I'll dig around the garage to see if I can find a stock one to verify it should have the bend in it.
Old Jan 10, 2017 | 09:34 AM
Nihayde's Avatar
Thank you
Old Jan 10, 2017 | 08:22 PM
rcorrigan5's Avatar
Randy C.
I had to replace the one in my '69 4-4-2 and the replacement piece came without the bend. I had to put the bend in it myself, which I did with a couple pair of vice grips. It turned out surprisingly well and the new assembly fit together nicely.
Randy C.
Old Jan 11, 2017 | 04:54 AM
Nihayde's Avatar
Thank you much.
Randy C.
My2nd 69 442
Aug 17, 2016 06:15 PM
4Ceesuns
Jun 6, 2014 02:54 AM
MN71W30
Mar 9, 2013 02:37 PM
wmlewis
Mar 15, 2012 10:21 PM
Steve Wike
Oct 26, 2010 06:35 AM
