Speedometer not working - speedo drive gear
Old Sep 23, 2018 | 06:28 PM
Via3d's Avatar
My speedometer stopped working suddenly yesterday.
I am able to turn the cable and see the speedometer as I do it.
Thus the drive speedo gear or the inner shaft speed gear is likely bad right?
What would cause either of these 2 gears to strip? I did shift down to low yesterday at low 10mph speed.... gently D to 2nd and then 2nd to Low. (TH350 automatic) . Driving in low seemed a little rough but cant tell for sure.
I dont want to go changing a plastic gear for it to just strip again if there is something causing this, that I have another issue.
Thanks in advance for input.
Old Sep 23, 2018 | 07:33 PM
don71's Avatar
same but different
The cable is stamped into a square shape and fits in the gear. I'd suspect that the female end of the driven gear has gotten worn more so than a stripped gears scenario. But it could happen. You're going to have to have a look and see. Pretty easy to repair....er replace.
Old Sep 23, 2018 | 10:42 PM
Actually the root cause is usually a bad speedo cable. This causes excessive drag on the gears, and one or both wear out.
babailey
Mar 7, 2018 05:18 PM
jpc647
29
Sep 8, 2017 09:02 PM
88hurstolds
Aug 5, 2015 09:00 AM
1BOSS83
Jan 15, 2014 05:14 PM
delta254
Drivetrain/Differentials
Oct 18, 2012 10:11 PM
