Speedometer not working - speedo drive gear
My speedometer stopped working suddenly yesterday.
I am able to turn the cable and see the speedometer as I do it.
Thus the drive speedo gear or the inner shaft speed gear is likely bad right?
What would cause either of these 2 gears to strip? I did shift down to low yesterday at low 10mph speed.... gently D to 2nd and then 2nd to Low. (TH350 automatic) . Driving in low seemed a little rough but cant tell for sure.
I dont want to go changing a plastic gear for it to just strip again if there is something causing this, that I have another issue.
Thanks in advance for input.
The cable is stamped into a square shape and fits in the gear. I'd suspect that the female end of the driven gear has gotten worn more so than a stripped gears scenario. But it could happen. You're going to have to have a look and see. Pretty easy to repair....er replace.
