Sport mirror internal reinforcement?
Well after 3 months I finally got my new door panels from Legendary and while I'm installing the fronts I'm going to be installing a pair of sport mirrors I got a while ago (thanks Bill!). My car currently has a drivers-side chrome mirror.
My question is I believe I need some internal reinforcement for the sport mirrors since I'm introducing these to a car that never had them. I can fabricate something but it would be good to see what is normally used and I haven't got a clue. It looks like OPGI sells a pair of reinforcements but that's the only reference I've seen, but there is no picture provided.
Has anyone done this that can give me some tips?
Thanks in advance -
Thanks in advance -
I used a piece of 1/8" thick flat aluminum plate long enough to span the two attaching screws. I pre-drilled holes for the screws then held it in place inside the door while I attached the mirror base.
Dalilama, you are right the picture you posted that part is required for sport mirrors like you said for reinforcement to keep the mirror from moving. Am doing the same thing to my 72 cs. I haven't put the passenger side mirror on yet because I do not have that piece. I originally had the chrome mirror on my driver side door too. If you have your driver side door panel off look up towards where the mirror go and you will see that piece.
costpenn
Aug 29, 2018 11:42 AM
Oct 16, 2013 05:35 PM
