Build sheet question
Old September 3rd, 2018, 05:24 PM
72455's Avatar
Getting ready in the next few days to track down the build sheet on my 72 Cutlass Supreme. Mine is a Freemont built car which means I should find it on top of the gas tank. Did they put them in the same spot on the gas tank?
72455 is offline
Old September 3rd, 2018, 06:15 PM
Randy C.
rcorrigan5's Avatar
If it's there (sometimes, even on a Fremont car, it's not there or anywhere else on the car), it could be anywhere above the gas tank. I found mine between the gas tank pad and the trunk floor sheet metal, towards the forward end of the gas tank on the driver side.
Randy C.
rcorrigan5 is offline
Old September 3rd, 2018, 08:56 PM
The one on my '70 Supreme (Fremont car) was between the gas tank pad and the gas tank. The edge of one corner was sticking out so I never would have seen it if I hadn't dropped the tank.
Fun71 is offline
Old September 4th, 2018, 03:27 AM
72455's Avatar
So is it "tucked in" or hidden or will it be in plain sight? Reason I'm asking is I'm gonna use a bore scope to take a look.
72455 is offline
Old September 4th, 2018, 06:04 AM
First, there is no guarantee that you will find one at all. Second, there was no "standard" location. You MAY find it on top of the tank, if you are lucky. You may also find it somewhere else entirely, or not at all.
joe_padavano is offline
Old September 4th, 2018, 11:19 PM
MOTORHEAD
11971four4two's Avatar
on a fremont car??
under the carpet
under the package tray (rear window)
gas tank = seldom
happy hunting
11971four4two is online now
Old September 5th, 2018, 06:01 AM
Good thing the 72's didn't have the gas tank pad.
Allan R is offline
Old September 5th, 2018, 06:15 AM
72455's Avatar
That's good to know Allan. Thanks.
So when I drop the tank (and if the build sheet is there) I should see it, right?
72455 is offline
Old September 5th, 2018, 07:16 AM
jaunty75's Avatar
This won't be enough. To properly locate a build sheet, one needs at least TWO ground-penetrating sonars, a CAT scanner, one scanning tunneling microscope, and a pad of paper attached to a clipboard with two sharp pencils with clean erasers.
jaunty75 is offline
Old September 5th, 2018, 08:14 AM
Randy C.
rcorrigan5's Avatar
When I found mine, I thought the task of doing it would be difficult, but it wasn't. I simply loosened the bolt to the each of the two straps that hold the gas tank in place (didn't take them all the way out and, fortunately, they loosened quite easily - no rust, no corrosion) so I could look up into the area between the tank and the pad and the trunk bottom and, there it was. I didn't even have the car on a lift or raised up - it was just what I could reach laying under the car. I was careful to extract it so it didn't tear and it came out intact without completely removing the gas tank. For starters, just take a look and see what you can find. It may be easier than your mind is telling you. And having your car on a lift would make the job even easier, if you have access to one! Keep in mind, however, that there may be nothing at all. A lot of cars from Fremont had build sheets stowed in them somewhere, but many also did not.
Randy C.
Old September 5th, 2018, 08:48 AM
72455's Avatar
Lol...you forgot the the part about standing on my head and counting my toes😀
72455 is offline
Old September 5th, 2018, 08:50 AM
72455's Avatar
Randy C.
Thanks Randy..did you loosen all 4 or just the front two bolts?
72455 is offline
Old September 5th, 2018, 09:13 AM
Randy C.
rcorrigan5's Avatar
I just loosened the front two bolts which lowered the front end of the gas tank somewhat, but just enough that I was able to see that a piece of paper was there. It was also just enough that I was able to weasel that piece of paper out of there without damaging it. I started at the front end (that is, towards the front of the car) because I thought I could see something but I wasn't sure if it would be the build sheet. As it turned out, it was the build sheet. I believe the bolt that holds each of the two straps up in front are rather long so it gives you some room with which to lower the tank without dropping it. Someone correct me on bolt length if I'm wrong.
Randy C.
Old September 5th, 2018, 09:29 AM
If it's there, yes.
Allan R is offline
Old September 5th, 2018, 12:31 PM
72455's Avatar
If it's there, yes.
I lowered the front of the tank and didn't see anything...felt around the front...nothing. Even took a look with the bore scope just to make sure, and zilch. So either it's gone the way of the dodo or it's somewhere else. I've checked the package tray and under the rear seat cushion and behind the rear seat back...any ideas?
72455 is offline
Old September 5th, 2018, 12:40 PM
My442's Avatar
The last 3 cars I have owned came from Fremont.
All 3 had build sheets on the top of the gas tank.
2 70 Olds and a 69 Chevelle.
All were in great shape.
My442 is offline
Old September 5th, 2018, 01:38 PM
Randy C.
rcorrigan5's Avatar
Keep in mind that it might not be on your car at all. The Lansing plant was fastidious to their rules and either no one, or next to no one, has ever found a build sheet from there. Sometimes the build sheets might not be there from other assembly plants as well. I looked all over my '69 4-4-2 convertible (Fremont car) and never found a build sheet. It could very well be that your build sheet never made it to your car as well. I should add that the build sheet I did find was on my '70 GTO (also a Fremont car).
Randy C.
Old September 5th, 2018, 01:47 PM
72455's Avatar
And I should add that the PO had the gas tank cleaned and re lined...so I may be chasing a ghost...
And there is no way to get a replica, correct?
72455 is offline
Old September 5th, 2018, 02:22 PM
Oh, hell, if the tank has been out before, there won't be anything there now.
Correct. That information does not exist. Oldsmobile didn't have a reason to save it, so why pay to store it.
Old September 5th, 2018, 02:39 PM
72455's Avatar
Oh well...at least I gave it the old college try. If nothing else, I know it's a numbers matching car, and there's still hope with my research in the fact that the dealership that sold the car is still in business. I have a call into the guy that handles records and archives, and he's doing some digging.
Will keep you posted and thanks for all the help, even though my quest bore no treasure.😣
Dave
72455 is offline
Old September 5th, 2018, 05:57 PM
And I should add that the PO had the gas tank cleaned and re lined...so I may be chasing a ghost...?
If you had mentioned that earlier I would have told you to not bother.
I'd say the chances of them finding the records for your car 46 years later are about the same as you finding the build sheet on a tank that's been out already. Sorry, but good luck.
Allan R is offline
Old September 6th, 2018, 02:03 AM
The build sheets, sometimes called manifests, were a grocery list, for lack of a better term, of what to put on the car on the line. Once the car was built, they have served their purpose and needed to go away, either being stashed or being tossed, and this is why there is no standard on how they worked.
A Chevy I own has two build sheets, and one from the El Camino that was in front of it.
Koda is online now
Old April 18th, 2019, 09:14 PM
savage'74's Avatar
Build sheet
My build sheet I found behind passenger side rear interior panel and in very good shape
savage'74 is offline
Old April 18th, 2019, 09:30 PM
savage'74's Avatar
Build sheet
Old April 19th, 2019, 07:35 AM
w30brad's Avatar
I found two copies of the build sheet in a Fremont built 1969 442 I used to own. One was under the rear passenger side carpet and the other was under the rear drivers side carpet
w30brad is offline
erke88
June 29th, 2018 12:10 PM
alburk
January 28th, 2016 09:43 AM
allandennis
October 18th, 2015 08:26 AM
stratoblues
July 9th, 2014 03:41 AM
dan1s
September 4th, 2009 07:43 AM
Quick Reply: Build sheet question
