- are 68-69 Cutlass radio face (bezle) the same?
- Installing a Griffin Radiator in a 67' 4442
- Door Lock Pillar Weatherstrip
- Superlift shock questions
- Fuel Tank Options
- fuel: lead additives
- Paint for Plastic?
- A/C Freon leaks? Check the little easy stuff first!
- Summit Direct Fit Aluminum Radiators
- Classic Auto Air Upgrade Kit for 1968-72 Cutlass
- Console Mounted Vacuum Gauge
- A/C compressor leaking
- Old Gas.
- Window rollers
- 67 olds ninety eight DOME LIGHT removal
- Heater and ac ductwork
- Heater hose routing
- 1970 cutlass a/c parts needed
- 66 cutlass vent window assembly removal
- A/C Compressor Question
- Cutlass Evaporator core?
- Oil leak from evaporator case
- door opens with key but not with remote
- Air Condition
- Door won't unlock
- AC Recharge Questions
- Freon transfer from one car to another?
- 1968 cutlass radio
- 66 Toro - Cruise cable
- AC Alternator Brackets
- 68 cutlass tilt wheel with auto shifter
- 455 Coolant Overflow Bottle
- Which parts need to be "original"
- 1972 Supreme Radiator
- Dash clock
- Trunk liner
- Adding A/C
- 1966 F85. Recharge R12 or convert?
- Charcoal canister delete
- Need pictures of a/c bracket on 324
- Rebuild parts for '66 A/C Compressor..
- 1968 Cutlass tilt and telescopic column
- Vent selector door
- 62 Starfire Heater Core Bracket
- Z-Gate in a 70-72 Console
- Seat belt bolt question
- Dome light stays on
- Gas gauge problem here
- heater noise whistle?
- vinyl top install help?
- tightening side mirror?
- wiper cabel directions 1955 olds
- 69 cutlass S Hood Moulding?
- How Did You Install Your Gauges
- 1968 cutlass Tilt installed into non tilt car
- Fuel sending unit???
- numbers on glove box
- Aftermarket A/C manufacturer in San Antonio, TX
- 62 starfire vacume diagram
- 69 442 Windshield Installation
- Hurst Dual Gate shifter question
- Vinyl flooring
- Rubbr/soft fuel line sizes
- My 72 Cutlass
- 1964 Super Eighty eight
- rear window weatherstripping for 72 cutlass?
- pictures please
- heater confusion
- What Tool Is This (Carb Measuring Gauge)
- 69 cutlass A/C duct work
- 68 delta 88 fan switch cap screw size
- Electric antenna for 64 dynamic 88
- Help needed with AC Heater controls
- 1963 f-85 convertible turn signal lense
- 68 cutlass gas tank
- 1967 vs 1968 98 taillights
- Rally Pack Quality?
- Interchangibility
- 69 defrost controller
- Seat Belts - Retrofitting
- weird 72 cutlass
- Air blend door on 1986 Cutlass
- 1993 olds cutlass starting question
- hole in radiator
- Turn signal lever broken on 62 Dynamic.
- convertible top hose replacement
- Service Parts I.D. codes help...
- 55 vent window latch
- 1968 Cutlass S Windshield
- Floor Mount Dimmer Switch Testing
- 1982 delta 88 gas tank problem
- Radiator Shroud help
- Best practice for removing pipe from trumpet tip?
- Tri Carb Linkage
- Source for Replacement Gas Tank 65 Delta
- 68/69 Cutlass Speedo Faceplate/needle RnR
- 1966 Toronado headlight repair
- Gas tank repair
- 1968 Cutlass S Conv Dash Hole ID
- Quick Question about Fuel Pump to Carb Line
- Instaling a "Hidden" CD Player
- parade boot option?
- Might be in the wrong place, but I have a door question.
- Antenna ID ???
- Vent Window Channel Weather Strip Replacement
- Windshield Wiper Refill (rubber)
- Anybody Any Good With Windshield Washers?
- 70 SX Air conditioning recharge
- 62 Olds Grounding wires
- AM radio preset Q?
- A few questions...
- 70 radiator ?
- Vac trunk cylinder not working? Try this....
- restoring hardware
- power window help
- convertible top frame rail bent??
- info motor pump
- 77 Cutlass
- Speaker kick panels for '70 Cutlass w/o AC
- Confused by vacuum pump wiper...
- vinyl roof
- Dash - instruments-dash pad-removal ???
- dash illumination
- AC Help..pics inside!!!
- 1971 Cutlass 442 AC questions
- 71 Cutlass Conv. wiper motor
- Backup Lights
- Hood Release
- 62 Starfire Vacuum routing diagram
- blower motor fan, good or bad?
- how to mount on-dash tach (1966, 442)
- 66 toronado headlight setup
- Ignition help?
- Speedometer help needed
- Correct looking wiper blades for 1966
- passenger window goes down but falls in
- window stop adjustment
- Classic AC Parts & Work!
- Free flowing 2.5" dual exhaust
- Replacing Ignition
- radio speaker question
- Window/sunroof seals: where to get?
- Factory or Dealer Installed A/C
- top cylinders
- top wont go up or down
- Removing A/C and heater?
- Speedometer Part Question
- 71 Cruise Vacuum Diagram
- Interior Hose routing from the Heater Box???
- radiator for 64 cutlass
- 1972 Cutlass factory air question
- Ot Cell phones
- Looking for part#
- 67 F85 Wagon Parts needed
- extension rocket emblem
- Air Flow/Cooling/A/C Question
- Miscellaneous Parts for 1970 Bullet Mirror
- rechromed trim
- 1/4 window has slack....help
- 1978 98 regency diesel problems
- 1964 Olds shop manual
- AC delete
- receiver dryer replacement question
- Stainless braided upper radiator hose - any problems?
- Question regarding AC Delete.
- Air Conditioning Questions
- Lower radiator hose
- Wiper Motor needed
- Exhaust mod question
- Lost Trunk Key
- air
- 1973 olds 98 window parts
- Jetstar Air Conditioning Unit
- Ingram Oldsmobile...Mansfield, Oh.
- wiper switch needed
- Radiator Swap
- Exhaust manifold question
- Stock Radio Volume is Low
- Shift indicator linkage question
- Dim brake/signal lights
- Light lense/ cover or whatever its called
- Brake fluid canister needed
- foul odor
- 1984 98 Opera(?) Lights
- remove heater core on 64 cutlass
- Turn signal cam
- 15" wheels
- bad gas
- Dash Speaker - Aftermarket
- Adding a/c to a NON a/c 69 Cutlass
- 72 Cutlass 134A conversion
- pressure washing a 3800 V6
- Float Drop?
- Carb Help
- '65 F-85 Convertible
- VIN number for a '76 98
- 89 Cierra
- fender wells
- Not Olds but close. Motor and trans swap in 1961 Buick Special
- LOL
- wheel size for disc brakes 71 cutlass
- SHOCKS FOR A 1985 DELTA 88 ROYALE
- Our Toys and the Economy
- Barrett - Jackson
- I never expected this!!
- Best car movies of all time!
- quadrajet missing the "70"
- Exhaust tip length
- MIG welder preference
- Shocks '61 F85
- Need some rigging idea or help
- 2bbl-4bbl swap
- What do you know about these wheels?
- 65 Cutlass Tires and Rims
- 1948 Olds "little Brother" build
- 1968 cutlass grille
- America On Wheels picture thread.
- seen a funny olds at the yard today...?
- 40's and 50's Olds Forum opinion
- Paint for my 63 F-85
- Heat Riser (manifold heat control valve)
- Air bag suspension.
- Any good junkyards in Ohio??
- Citcapp, was that you?
- slight engin smoke
- Air filter hold down
- Useful Idea for somebody Maybe?
- heater won't turn off
- My new Toy, Dans younger Brother
- 442 registry??
- discussiong our addiction
- New title for a vehicle in Canada
- engine paint color
- 68 air cleaner
- how to bring back anodized aluminum?
- DVOC Show Sunday Downingtown Pa.
- air scoop fittment
- What kind of Carburetor is this?
- Why doesn't these Manuals on DVD help?
- HUH??? Say What?
- Need help with vacuum lines 1962 Starfire!!
- Headers
- I need to get some aluminum trim anodized
- Assistance please
- picture to show up with your post
- exhaust pipe on newer Olds
- Need To Re Do A/c For A 1971 Cutlass
- Anger management
- A/C Compressor / Belt Question
- Pick-Your-Part inventory
