Adding A/C
Old May 16, 2011 | 07:06 AM
1971 Olds 442's Avatar
Adding A/C
I want to add an aftermarket A/C to my 71 442 w/455. Any recommendations on what brand or where I should purchase it from? Also looking for two lapbelts female side, mine are missing. Any ideas? Thanks
Old May 17, 2011 | 05:30 AM
garys 68's Avatar
I've installed both Vintage Air and Classic Air kits, I was happy with both.
The Gen IV VA (electronic controls) is a pretty high tech unit and costs a couple hundred more than the CA unit. The only downside to the CA cable operated universal unit is that there's no separation between the defrost and heat ducts. The controller simply shifts airflow between 4 dash ducts and 4 heat/defrost ducts.
Neither makes a direct kit for a 68-72 cutlass, so when I wanted to put one in my 72, I went with the simpler CA universal kit. You can adapt the original AC controls to work with the CA unit.
If you want any info, feel free to contact me. I have pics of the install too.
Old May 17, 2011 | 05:41 AM
You mentioned the with the CA kit you can adapt that to the original controls. My car does not have factory A/C. I was looking to just adding an underdash unit. Get's a little hot here in Florida.
Old May 17, 2011 | 05:54 AM
garys 68's Avatar
I think the non-AC cars have 3 lever control, the AC 2 lever. You would only use 2 levers hot/cold and dash/heater. The control levers are the only thing you keep from the old system.
Personally, I dont like the look of the under dash models.
Better hurry, I was in FL last month and already used the AC.
Old May 17, 2011 | 06:16 AM
Thanks for the info. Time to start shopping around.
Old May 17, 2011 | 11:25 PM
garys 68's Avatar
If you go with Classic Air, there are a couple substituted parts that will make the install cleaner. Just let me know.
Old Jun 9, 2011 | 07:45 PM
hamm36's Avatar
oldairproducts.com
Another one to look at for after market AC Parts.
They give a 10% veterans discount.
Old Jun 9, 2011 | 08:08 PM
oldspackrat's Avatar
Give me a call or pm, I have some pretty nice seat belts & tons of other stuff you didn't know you needed.
Scott
c. 317-727-7041
Old Jun 10, 2011 | 07:03 AM
Thanks guys, I already ordered my AC and getting it installed this weekend. Thanks Scott I will give you a call this weekend. Do you have the deluxe belts or the standard?
Old Jun 11, 2011 | 04:19 AM
Alb's Avatar
Alb
A/c
Both controls on a 69 have only 2 control *****. They are different as to what you have. A/C or not. The non air is mark Heat and defrost on the A/C one. It is marked Heat,defrost, vent, normal and recirculate. That is the top lever. The botom is marked. Cool or warm.
Alb
Steve Wike
Jul 17, 2009 10:19 AM
BLESSEDBYGOD
Mar 15, 2009 06:32 AM
JSGD1966
Oct 30, 2007 01:39 PM
perro
Sep 4, 2007 11:52 PM
