Removing A/C and heater?
Old Feb 15, 2010 | 06:48 PM
yeahbuddy's Avatar
Considering removing the A/C and heater from 68 Cutlass Supreme. It is not functioning and is not hooked up. I would like to clear up the engine bay a bit. Is removal a big job? I am going to be ordering a firewall cover if I decide to go for it.
Old Feb 16, 2010 | 02:54 AM
Mongoose's Avatar
As an alternative to removing all climate control, check out acdelete.com for the cover to clean up the firewall. Their units will convert your system from A/C to heater only without having to weld in several plates (or an entire non-A/C car firewall) to cover up the holes used for A/C.
Might be a preferred way to go instead of removing everything.
Old Feb 16, 2010 | 06:29 AM
Mongoose has a good point. There are a few aftermarket suppliers that make non-AC air plenums for people removing the AC from their car. The hardest part of removing the AC from your car is taking the passenger's side fender well out to remove/replace the air plenum.
smcurro
Mar 16, 2018 08:37 PM
5998DownUnder
Jun 9, 2014 09:35 AM
Oldssupreme
Mar 12, 2013 10:56 PM
Steve Wike
Aug 22, 2010 06:45 PM
DJMatthews
Dec 12, 2006 06:36 AM
