Factory or Dealer Installed A/C
Old Mar 7, 2010 | 05:08 PM
defiant1's Avatar
I am learning a lot about the car. But not sure on the A/C I have in the car. Based on the pictures, is the A/C factory or an after the fact installation?
Also the hose near the accelerator pedal, I see where it hooks to the AC but need to know what it does. Is it a drain hose? Whatever it is, it is in an inconvenient spot as your foot keeps knocking it off its connection.
If anyone has the same setup, please let me know.
Old Mar 7, 2010 | 05:17 PM
70 cutlass s's Avatar
That's not factory A/C. I don't have any idea what the hose is for.
Old Mar 7, 2010 | 05:32 PM
defiant1's Avatar
Okay, that is a start. I guess I will see what kind of markings I can find on the AC to give me a better idea where/who installed it.
Old Mar 7, 2010 | 05:38 PM
VikingBlue's Avatar
maybe it's a drain hose like room air conditioners have..for an aftermarket AC unit.
Old Mar 7, 2010 | 08:59 PM
yzzerdd's Avatar
Smile
Yes, on the bottom of the A/C unit, you can see a protrusion (was going to use the word nipple, but decided protrusion might be a little better) that the hose appears to have been disconnected from. Reconnect the two. As suggested above, it seems to be a drain hose.
--Jack R.
Old Mar 7, 2010 | 09:21 PM
redoldsman's Avatar
Proud Viet Nam Veteran
The hose is definitely a drain hose because those things create a lot of moisture since they remove moisture from the air. It is for sure aftermarket and could be manufactured by John E. Mitchell company in Dallas or ARA in Fort Worth since they were large manufactures of aftermarket A/C units. Of course there were a number of other companies but these are two that come to mind. Does it still work?
Old Mar 7, 2010 | 09:39 PM
defiant1's Avatar
The previous owner said the AC worked. I have not tried it yet as I am working on the motor, changing fluids, belts, gaskets etc.
Now that you mention ARA, I believe that is what is written on the front of the unit.
Thanks for your help.
Old Mar 8, 2010 | 06:03 AM
rocketraider's Avatar
Oldsdruid
If that unit works, it will outperform the factory A/C. Only thing is all the aftermarkets were recirculating units and don't give you an outside air option.
Old Mar 8, 2010 | 06:14 AM
jeffreyalman's Avatar
I had all 3 of my recirc doors wired shut so I never get outside air, A/C is 40 deg at the vents on all 3
Old Mar 8, 2010 | 06:52 AM
Lady72nRob71's Avatar
Put a small worm drive clamp on the condensate hose to secure it. Last thing you need is water draining inside...
Great idea for driving in big cities with lots of smelly diesels...
I plan to install a switch in my AC system to allow for a recirculate option when using the heat.
Old Mar 8, 2010 | 06:53 AM
my era cars only had recirc on max fan, now I have it on all speeds
dmberendsen
Dec 29, 2013 06:10 PM
CutlassLegend
Aug 13, 2011 05:09 PM
bobb
Body work
Oct 8, 2010 01:48 PM
RAMBOW
May 27, 2009 09:29 AM
442much
May 8, 2009 07:09 AM
