1993 olds cutlass starting question
Old Dec 1, 2010 | 02:52 PM
Jim w's Avatar
As the cold weather is upon us in Minnesota my car seems hard to start. Its good if it fires right away(acted up 2X so far). After cranking quite a bit it starts.
I am used to newer cars that you never press the gas on. Is there a trick like holding it partway down or something.
Any help would be appreciated.
Oh I have the 3.4 V6..
Old Dec 1, 2010 | 02:59 PM
jaunty75's Avatar
But your car, even being a '93, IS a newer car, isn't it? By "newer," you mean fuel-injected, right? No carburetor? No pressing the gas pedal to the floor to set the choke?
You should never have to push down on the gas pedal to start the car, warm or cold engine, winter or summer weather. If it requires excessive cranking, there could be any number of reasons. How many miles on the car? When were the spark plugs last changed? When was it last tuned up? Fuel injectors cleaned?
Old Dec 1, 2010 | 03:09 PM
Jim w's Avatar
It is fuel injected. The previous 2 owners kept fairly good records. New fuel pump and filter last 2 years. I seem to have trouble is when I let off the key a bit early. Plugs and tune up not listed so maybe that would be a good place to start. I put 2 cans of sea foam in the last few months but never cleaned the injectors other than that.. Thanks for your quick reply!!
Old Dec 1, 2010 | 03:15 PM
Redog's Avatar
Get your battery checked. Cold weather and batteries don't get along very well. When you turn the key "ON" (not starting) the volts really shouldn't be much below 11.9
Old Dec 1, 2010 | 03:21 PM
Jim w's Avatar
1month old battery. Alternator tested good and is fairly new.
Old Dec 1, 2010 | 03:26 PM
Redog's Avatar
Hmmmm.... I would look at the plugs and wires next. Have they ever been replaced? What about coil packs and ingition control mod? Fairly cheap, if you know where to look
Old Dec 1, 2010 | 03:32 PM
Jim w's Avatar
I probly try plugs and or wires next. It runs great and got me 28 mpg to SD. But that does not mean maybe the plugs are not bad.
Old Dec 25, 2010 | 10:36 PM
Jim w's Avatar
Car running good now. Idler motor (new) and cleaned plates. Off the topic we have had a record snowfall here in MN. Seems to handle well os far.
Old Dec 25, 2010 | 11:24 PM
Jim w's Avatar
My Car
This is the Car. First attemt posting a picture on here so be gentle.
ducksalot
May 22, 2014 11:17 AM
rocketman77
Sep 13, 2013 04:25 AM
bccsrc
Nov 29, 2011 11:08 PM
ashkil
Jan 3, 2008 06:45 AM
bihorelp
Jan 3, 2008 06:43 AM
