15" wheels
Can anybody tell me the benefits of changing from 14" to 15" wheels besides the fact that they fill the well more or the car travels farther for one rotation of the bigger wheel. What is the effect on handling and why?
As an example, a 215/70-14 tire and a 215/60-15 tire are both nearly the same diameter. In fact, the 15" tire is about 1/2" SMALLER in diameter than the 14" tire. The big difference is the 15" tire in this example is a lower profile 60 series, which will improve handling due to the shorter sidewall.
https://classicoldsmobile.com/forums...2-cutlass.html
Will the 15" SS wheels fit rear discs? If so, what company/brand kit is it? There was another thread recently dealing with 15" SS's and rear disc fitment problems. I would like them on my Vista if it wouldn't be too much of a project and I could use stock wheels. Even with standard front discs it's an adventure when you pull back on the reigns sometimes.
I did a 4-wheel disk conversion on my 72" Cutlass and encountered two problems.
First; the rear GM rotors were about 1/32" too small for the outer diamater of the hub. To correct this I had to do some sanding and grinding on the hub, but it eventally slipped on like a glove. (By the way; if you have to do this be sure to have the hub spinning so that you can sand evenly. You may also consider just taking the rotors to a machine shop and having them shave the rotors.)
Second; once I got the rotors and calipers on and mounted the rims, I found that the calipers rubbed on the wheel even though it was 15". Aparently the center of the 15" SSIII is the exact same center as the 14" SSIIs. The outer part of the wheel is just larger. To correct this I had to buy new, longer (2 1/8" long) set of wheel studs and a set of 1/2" wheel spacers.
I drove out the old wheel studs with a hammer and used a washer with a nut and my impact gun to pull the new studs through the hub. I then put the calipers back on, slid on the spacers, and mounted the wheel. The spacers set the wheels out enough to give me about 1/4" clearance from the caliper.
I haven't had a chance to corner with it yet so I don't know if they will end up rubbing, but if they do I will may have to try and go out to 3/4" spacers. (Hopefully, not.)
Anyway, hope this helps. Oh yeah, I got the brake kit through a reseller of MBM brakes. I was a bit disappointed in the fitment and the fact that they sent me two different lengths of E-brake cables. But then again modifying a car away from stock sometimes does require a bit of sawing, grinding, and banging on to get into place.
Other than that the set seems pretty solid so far.
jim larson
Apr 1, 2016 02:13 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
81 regency
Apr 21, 2011 06:18 PM
