Air Condition
Old Jul 1, 2011 | 03:52 PM
86Regency's Avatar
Air Condition
I have a 1985 Oldsmobile Regency..
Everytime I turn my fan on the A/C fuse blows, but if I keep it off,and it does not blow. My A/C compressor does not work right now, and was going to buy it, but I figured this problem out, so I want to fix this first. What coul cause this?
Old Jul 1, 2011 | 04:35 PM
Lady72nRob71's Avatar
On all speeds or just one? Try to find the fan motor lead and disconnect it close to the motor. If the fuse no longer blows then the motor is shorted or stuck.
Old Jul 2, 2011 | 10:35 AM
86Regency's Avatar
Well, I didnt get a chance to put it on any other speed, but whenever the fuse blew I put a new one, same size (25) and it stayed on a little longer, about a minute, and my car also turned off!
Old Jul 2, 2011 | 07:05 PM
Report back your battery voltage at the terminals with the car running. If you are dropping voltage (causing your lights to dim in your other thread) then that could cuse the motor to pull more current and blow the fuse.
Old Jul 2, 2011 | 07:13 PM
Redog's Avatar
Fix the voltage problem first, then we'll work on the A/C.
A car doesn't need to A/C to be driven
Old Jul 16, 2011 | 02:02 PM
86Regency's Avatar
Okay guys, the problem was the connector that goes to the A/C compressor, it was touching metal causing a short. Thanks everyone for your help. I still cant find what makes my car sit sideways thouh. Help.!!
headlines
Jun 29, 2013 05:56 AM
nbfalj
Tech Editor's Desk
Mar 24, 2013 08:31 AM
cal cleveland
Jun 22, 2011 10:23 AM
Jura
Ninety-Eight
Feb 9, 2010 12:00 PM
fjross
Nov 17, 2009 03:06 PM
