1970 Cutlass Wiper Problem
Old Jun 15, 2015 | 07:27 PM
Mspalding3's Avatar
Last week I installed a new wiper switch in my 1970 Cutlass and while the wipers technically work now, they are not running correctly. They go up about 2 to 3 inches and then go back down and they just keep doing it. I don't have a lot of experience with the wiper system on these cars so I was wondering if anyone else had any ideas? Thanks guys!
Old Jun 19, 2015 | 06:46 PM
Mspalding3's Avatar
Bump
Old Jun 20, 2015 | 09:26 AM
This problem is usually caused by either a bad wire to the wiper motor or bad contacts in the park circuit of the motor itself. The Chassis Service Manual has a troubleshooting section on this exact problem.
Old Jun 20, 2015 | 07:42 PM
oldspackrat's Avatar
I had a wiper switch do this recently & went to replace it & found out one of the screws that hold it to the dash was a bit loose & that screw provided the ground path to the dash ground. I tightened it a turn or so & problem solved. Might not be your issue but good to check. The switch was also getting very hot to the touch after running for 5-10 minutes which could be explained by high resistance in the ground circuit I believe.
Old Jun 20, 2015 | 07:58 PM
Mspalding3's Avatar
I will definitely have to check both of those out. Thanks for the reply guys
oldspackrat
Mar 12, 2015 06:34 PM
Oldskeeper
Sep 15, 2008 06:59 PM
a6m5zerosen
Jan 3, 2008 05:44 AM
a6m5zerosen
Dec 29, 2007 09:17 AM
kcmo85toronado
Jan 22, 2007 07:28 AM
