Cruise Control Interchange
I am trying to figure out what Cruise Control parts interchange. I have a 1967 cutlass and have purchased some olds royal cruise control parts do any parts interchange? Do any other gm cruise control parts interchange?
Thank you,
Scott
Thank you,
Scott
That speed control switch with the rotary dial is from a '67 full-size (maybe other years near that, too), but the Cutlasses used a button mounted in the end of the turn signal stalk. You would have to cut a hole in the dash somewhere to mount that switch. The part in your first photo looks like the regulator that would mount under the hood. A cable runs from the transmission to the regulator and then from the regulator to the speedometer, so you would need those cables. You also need a vacuum source for the regulator, which is not hard to find, but, more importantly, you also need the vacuum servo that actually operated the accelerator linkage. I don't see that in your photos. I see three photos of the dash switch and one of the regulator. Without the servo, you can't do anything.
I think you need to keep looking for a complete setup that actually came from another A-body Olds of that year. That way you'll have the correct brackets to mount everything on, which is just important as the components themselves, at least if you want a factory look.
sbasinger@hotmail.com
Mar 10, 2019 05:23 PM
