replacement gas tank
Guys:
I need a replacement gas tank for the restoration project on my 66 Cutlass, the ones I find have a footnote that says "2 vents in the rear" My original tank had only one vent line on it with NO return line,would the second vent line be for a return line? If so, could I just cap off this line?
Thanks, Ron
Thanks, Ron
I have no direct knowledge of this but I don't see where capping off the 2nd vent or using it as a return line would cause a problem.
My 66 is like yours in that it has a single vent and no return line. If I'm not mistaken (been awhile since I looked at the tank) the vent on the original tank is up front on the right corner so if the new tank has vents in the rear you would have to extend your lines to attach it.
The vendors decided to make only one tank for 66 & 67, which has the 2 vents and is not correct for a 66. I ended up purchasing a 66 Chevelle tank which had only one vent, and swapped filler necks (the one from a Chevelle is too short).
Guys:
Thanks, Ron
Thanks, Ron
joemo
September 21st, 2022 04:47 AM
1carsick
October 17th, 2012 09:10 AM
Texas442
January 30th, 2012 05:36 PM
