1965 heater control unit removal
Old Oct 17, 2016 | 09:13 AM
GCH's Avatar
GCH
Any tip about this ? from under the dash or remove glove compartment
for easiest way to go
Old Oct 17, 2016 | 04:50 PM
Ozzie's Avatar
Which body?
Old Oct 18, 2016 | 09:50 AM
GCH's Avatar
GCH
Dynamic 88 -65 4 door sedan.
Have removed some parts and should se if i could remove the center vent
outlet to se more.The fan don´t work now either.
Old Oct 18, 2016 | 11:24 AM
Ozzie's Avatar
Are you sure that it needs to be removed? What is the problem with it?
Old Oct 18, 2016 | 12:29 PM
GCH's Avatar
GCH
https://classicoldsmobile.com/forums...brication.html
And now the fan don´t start when I push the "heat/def" buttons.
Maybe it´s possible to spray some lubrication from "the back" with heater control unit still mount in the car.
Was thinking that some lubrication would save parts from break
Can see some moving parts in the unit when laying on the floor
and push the "buttons".
Old Oct 19, 2016 | 12:26 AM
Ozzie's Avatar
Section 14 of the Chassis Service Manual is probably the best part to read. In order to remove the control it will be necessary to first remove the other things which are in the way. Just be sure to remember how everything was installed. If needed make photos first. As far as the fan is concerned, you will need to trace the circuit to find the problem. It could be the switch; the fuse; the wiring; or the fan motor (sometime they seize and need to be lubricated). Page 13-5 has the wiring diagram.
Old Oct 19, 2016 | 09:11 AM
GCH's Avatar
GCH
Hi thanks for tip,should take a look in the Chassis Service Manual.Should try to see if
the heater control has power,fan are running great and i checked the resistor
in the engine compartment.
Need to replace old hoses to the defroster outlets and vents also
Looked at 13-5 wiring diagram and between the fan speed control and 20 A fuse in the fuseblock there are a "main switch" .Guess this must be the "off" button to the left
on the heater control.When pushing "heat" or "def" the fan should start at once and when pushing "off" the fan stops.
Old Oct 25, 2016 | 07:25 AM
GCH's Avatar
GCH
Hi now are the heater fan working again,it was poor connection
in the feed cable to the heater control unit.
Glad i,m bought body and chassies manuals so i could see what to
look for.The feed cable was connected to the unit just above the
center vent outlet.Could see with mirrors and flashlights.
Started the car and checked movement in the diaphragm when parts
was gone and it looked ok.
Replaced dry hoses to the defroster outlets so i guess this will work better now.
Thanks for tip about this
/Glenn.
69442murph
Aug 29, 2024 05:13 PM
jfagerness
Apr 27, 2015 11:59 AM
1k442
Apr 15, 2013 01:45 PM
Tedd Thompson
Jun 18, 2012 01:03 PM
jdana24
Jul 13, 2011 11:15 AM
