Old car/gas smell.
Old Aug 14, 2012 | 11:22 AM
Benton Quest's Avatar
No Dr. but play 1 on TV
Old car/gas smell.
Hi All,
I have a 1970 442 and it runs great. I'm very pleased with it's performance.
It idles low at stops and seems like it might shut off, but it never does.
My problem is it's smell. It has a little of the old car smell which I like. But it also has a light gas smell that it starting to concern me. I have not noticed it bad enough that it follows me when I get out, but still a concern.
I smell it more in the trunk that anywhere else.
Is it possible that the gas cap is loose enough to do this? It is not tight fitting like my newer cars. It just goes on and it is not snug at all.
Any thoughts and ideas will be appreciated.
Thanks,
BQ
Old Aug 14, 2012 | 11:25 AM
It may be a fuel vent line cracked, or bad gas cap, leaking main fuel line or return line if it's equipped with one.
Look under the car for leaks.
Old Aug 14, 2012 | 01:19 PM
allyolds68's Avatar
I believe there's a gas tank vent cannister (or something like that) behind the rear seat on 70's. I'd start checking there
Old Aug 14, 2012 | 01:24 PM
allyolds68's Avatar
I stole this pic from Lady72nRob71 here:
https://classicoldsmobile.com/forums...9-cutlass.html
Old Aug 16, 2012 | 05:50 AM
Hi,
I tightened up the gas cap today and put the smell test on it and I think it is somewhat better. I will keep a nose on it.
I could not see the canister in the trunk. Where do I need to look for it.
I also can't see any leaks what so ever from the tank.
If if doesn't go away, I will take it to a prof and ask them.
Old Aug 16, 2012 | 06:00 AM
sixty9olds's Avatar
1970 and lower did not have a vent "stack" as pictured- I believe that was 1971-72 only. Your vehicle will have either a vent above the tank or a fuel vapor return line (tank to fuel pump).
Old Aug 16, 2012 | 06:30 AM
hookem horns's Avatar
Gas cap should be non-vented and snug. Get a cheapo at any parts store if in doubt. The fuel gauge sending unit on top of the tank can be another weak spot, but changing requires dropping the tank. Just another idea if the vent lines are OK.
Old Aug 21, 2012 | 06:24 AM
68oldscutlass's Avatar
Any update to this? I am having the same issue in my 68. Brand new tank and sending unit. I did not replace the few short rubber hoses yet like an idiot so that could be it. No leaks anywhere that I notice. Car runs great but the smell is definitely concerning.
Old Aug 21, 2012 | 07:50 PM
The smell is weaker since I checked the loose gas cap.
I'm still going to buy another one and see if the seal is better.
It does not feel as tight as I think it should.
Old Aug 24, 2012 | 02:29 PM
Ok so I figured out my problem. Someone told me as I pulled into pepboys that I was dripping gas. Apparently only happened when I turned or gunned it. Where the filler neck meets the tank has a hairline crack on top. Gonna try jb weld first otherwise ill have to get another tank. Sucks. Atleast I know why I'm going through a lot of gas now, abd why it stinks!
Old Aug 24, 2012 | 04:23 PM
BILL DEMMER's Avatar
Just the facts...
stinks? ... i love the smell of raw gas in the morning
bill
Old Aug 25, 2012 | 03:57 AM
Don't get me wrong, I love the smell of gas but definitely not this much. Hoping the jb weld works for now. Starting to strip car down for body work and paint the next 2 weekends. Can't wait to get her done!
Old Aug 25, 2012 | 06:50 AM
JB Weld, or a similar 2-part "gas tank sealer" should work fine, so long as you clean the surface well.
That is a common failure point.
Old Aug 25, 2012 | 12:22 PM
oldsguybry's Avatar
NOVICE car nut
If the seal inside the cap is all cracked and dry rotted then replace the cap
Old Aug 26, 2012 | 03:43 PM
OK, I got a new cap. Do I need a vented cap or a non vented?? It looks like the one on there is non vented. I do not want to use this one until I know.
Thanks.
fv64olds98
Oct 24, 2014 07:49 PM
rhp454
Tech Editor's Desk
Aug 19, 2014 12:12 PM
hurstoldz
Jun 8, 2012 05:44 PM
Danny Boy
Jan 25, 2010 02:05 PM
Keieljun
Nov 8, 2007 01:30 PM
