68 Cutlass Gear indicator
Old December 25th, 2011, 08:56 AM
rmoths's Avatar
Wink 68 Cutlass Gear indicator
I have a 1968 Cutlass with column shift. The gear indicator does not work. Does anyone know how this works or what's involved in fixing this.
Thanks Barb. ( Merry Christmas everyone).
rmoths is offline
Old December 25th, 2011, 04:40 PM
Randy C.
rcorrigan5's Avatar
I'm attaching a couple of pictures I just took with my phone camera that will hopefully show how the column shift indicator works. Behind your speedometer pod, there is a spring-loaded plastic lever. First, if you move this lever counter-clockwise as you look at it from behind the dash, you shift indicator in your speedo pod should move from PARK through all the gears to LOW. Second, there is a wire loop assembly with a metal tab at the end of it. The loop fits through the hole in the plastic lever and the other end (which has the metal tab) is screwed into your steering column sleeve under the dash (this "sleeve" moves in line with your column shift when you change gears). Remove the cover in the lower dash that is under the column to gain easier access. Hope this works for you.
Randy C.
rcorrigan5 is offline
Old December 25th, 2011, 09:05 PM
rmoths's Avatar
Wink
Thanks Randy for the reply! It's very thoughtful of you to take the pictures and explain this so well. It's great to have such nice people (Olds people) to help out with problems. This is a wonderful forum. Thanks again, Barb.
rmoths is offline
Old December 26th, 2011, 10:56 AM
Randy C.
rcorrigan5's Avatar
...and I've gotten so much help from many other people at this site as well. I agree with you that this is one of the neatest "help" sites for our Oldsmobiles.
Randy C.
Old January 27th, 2019, 11:53 PM
sportcutlass's Avatar
I'm looking for actual shift indicator needle. It's a yellow plastic piece. The loop on mine is broken. Do you know where I can get one? I can't find it anywhere. Thanks.
sportcutlass is offline
Old March 31st, 2019, 08:21 AM
1968 442 Convertible
bry593's Avatar
I've the same problem. Broken plastic indicator crank. I'm guessing this will be a "live with it" issue. No replacements unless buying a complete used speedometer, or making a custom one?
bry593 is offline
Old April 1st, 2019, 10:11 AM
bry593's Avatar
Well, I've decided I'm just dumb enough to think I can make one from steel wire and some epoxy. I'll probably spend 20 hours trying to make it work before it fails in spectacular fashion. I've made a lot of mistakes and this will probably be added to the list...
bry593 is offline
Old July 31st, 2019, 06:44 AM
Phoenix8990's Avatar
I just posted the same question and hadn't seen the old posts regarding it. Thanks for the pics and explanation. Those parts are missing on mine. But at least i know what was suppose to be there and know how it was suppose to work. This site is awesome!
thanks,
Steve
Phoenix8990 is offline
Old September 6th, 2019, 07:45 AM
MI68442W30's Avatar
Guys and Gals ,I have 4 of these 68 shift indicator needles ,that are all there and unbroken that I have saved from several 68 parts cars over the years.I do have 1 68 column shift speedometer. I saved them even though there was never a demand for them ,everybody always wanted floor shift speedometers. PM me if you still need one.
MI68442W30 is offline
Old December 5th, 2021, 08:14 AM
1968Cutlassfallbrook's Avatar
Hook and link on column shift
hi I was wondering if you might have the column shift automatic linkage the manual calls it link and hook that hooks to the column and indicator
1968Cutlassfallbrook is offline
Old December 6th, 2021, 09:29 AM
MI68442W30's Avatar
yes I do still have these parts and have what you need ,I will dig them out . you can send me a PM with contact info and I could send a pic if needed
Phoenix8990
August 6th, 2019 05:46 PM
olds 307 and 403
June 10th, 2017 04:25 PM
beepac
September 9th, 2013 10:22 AM
Dangerbird
February 18th, 2013 11:54 AM
FATRATMATT
October 16th, 2008 04:21 AM
Quick Reply: 68 Cutlass Gear indicator
