Convertible top pump
I am restoring my 68 Cutlass Convert. I removed the electrical pump for the convrt top it has not worked in a while does anyone know what kind of fluid goes in , mine maybe leaked some out at the fitting that's why maybe it was not working
tnks bruce
tnks bruce
Automatic Transmission Fluid (ATF)
And here's a link to instructions on how to go about filling and bleeding the pump. The same info can be found in a Fisher Service Manual.
http://www.chevelles.com/forums/showthread.php?t=113945
I would drain a little into a class container. I remember them using hydraulic brake fluid, but that is a long time ago, and I might have remembered wrong. If i is brake fluid, it will remove paint, but if it is transmission fluid, it will be red. Check, because the two don't mix well.
In researching this very thing, I read in the 1966 Fisher manual to use brake fluid. The next text I saw was the 1970 Fisher manual and it says use Type A (or equivalent) trans fluid. So somewhere between 66 and 70 it switched.
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
Bobac455
December 5th, 2013 01:15 PM
