housings in dash for lamps
Old Feb 29, 2012 | 01:28 PM
stlbluesbrother's Avatar
Question housings in dash for lamps
I forgot the name of the part mentioned in the Title of this thread. Never the less, see the pic below for an example.
Question: why is the texture grainy? And, why are sparkles mixed in with the color?
I want to paint these (there are 2 per dash), but want to know more before going about it. Thanks
Old Feb 29, 2012 | 05:26 PM
Lady72nRob71's Avatar
Dash floodlight housings.
They seem to have the same coating that many other little parts get, like clips, brackets, and smaller screws. I thought it is a plating called black oxide or manganese phosphate.
Someone will know for sure.
If you want to be very factory correct, I think Eastwood sells a paint much like that.
Keep in mind that once these are installed and the lenses installed, noone would ever be able to see them.
I found that Krylon high-heat spray paint has the same low sheen and color, just not the sparkles.
Old Feb 29, 2012 | 06:06 PM
oldzy's Avatar
Mine are the same. Zinc Phosphate or similar finish as above originally. My gas pedal rod looks the same (that dull grayish color with sparklies). I was thinking of sending them off eventually to brakeboosters.com to have replated (same place I had my steering box done).
Old Mar 1, 2012 | 07:24 AM
thanks guys
Christophe2m6
Oct 31, 2014 11:37 AM
Octania
Oct 5, 2013 07:28 PM
ROCKET VAPOR
Jun 11, 2013 10:17 AM
FATRATMATT
Aug 27, 2008 07:31 PM
DuezPaid
Nov 3, 2007 01:21 AM
