Under dash Courtesy Lamps
I'm in need of 2 under dash courtesy lamps out of an 68 Oldsmobile 88 or a 98 as long as they have the orange and white push together connectors. anyone have any that they are willing to part with?
Check out this link to Year One. Not sure if this is what you're looking for, but for brand new parts harness, it seems ok. B 4 U buy, check with them to see if it''s right for your car. If you know it is, go ahead.
http://www.yearone.com/serverfiles/f...ight&SM=1&SC=3
Another place you can check out is Supercars Unlimited. If they don't have your harness, they will custom make it. Haven't used them, but have heard good things about them. Here's their link: http://www.supercarsunlimited.com/Ca...epartmentID=29
I thing I know which lights you're looking for. Only thing I can't remember about full size (B Body) Olds is whether these have the plastic hoods over them, or whether they just clip into the dash like on the A body. I have a duplicate set (NOS) that I'm installing in my Cutlass, but like I said, I'm not 100% sure the two harnesses are the same. Good luck on your search.
Thanks for the sites Allen R but GSX455MAN had a set which came out of a 68 OLDS 98 which worked like a dream! They have the same factory plugs and mounting hardware that I needed. HATS OFF TO GSX455MAN!!!!
