Trunk Release Vacuum - 69 Cutlass
Old Jan 17, 2012 | 05:59 AM
Texas69's Avatar
The vacuum operated trunk release in my 1969 Cutlass Conv is not functioning. I have good vacuum through the lines all the way to the mechanism at the trunk latch.
The "plunger" inside the cylinder at the trunk release seems to lack an air-tight seal and does not allow the vacuum to pull the levers that turns the latch. When I manually pull the plunger, it releases the latch.
Can the unit be disassembled and repaired internally or am I best served simply replacing it? I can't imagine repair parts are available off the shelf for this.
Thanks!
Old Jan 17, 2012 | 09:31 AM
rocketraider's Avatar
Oldsdruid
Try spraying a little WD40 in it and see if the seal improves enough to operate. Past that, replacement is your best bet. Rubber diaphrams don't last forever.
Old Jan 17, 2012 | 01:15 PM
jensenracing77's Avatar
if you can't get it to work i have one that does. i couldn't guarantee how long it will last because it is so old but it does work. $15 shipped. if you figure out you need it let me know.
Old Jan 18, 2012 | 07:49 PM
Texas69's Avatar
Thanks for the advice and offers. After pulling the actuator unit and checking it more closely, the diaphragm may be OK. A more likely culprit here is a sticky lock cylinder that is hard to turn. When I get motivated, I'll remove it, clean and lube the cylinder to see if that works.
Old Dec 30, 2012 | 02:33 PM
Texas69's Avatar
trunk release - vacuum rod
Anybody have a picture of the rod that goes from the trunk lock, through the trunk latch, to the vacuum operated trunk release unit? I pulled mine and it is pretty chewed up, with several bend and kinks. It lookes nothing like the flat, straight replacement that came with a new lock assembly.
I Just wanted to compare to make sure I have the correct one, since my vacuum powered trunk release is not working
Old Dec 30, 2012 | 03:00 PM
oldspackrat's Avatar
The correct ones for the vacuum application have a ball & socket type set up. I don't have any pictures, but they are specific to these & if you don't have the correct one, you're going to have a hard time finding one.
Old Dec 30, 2012 | 03:26 PM
Texas69's Avatar
trunk
Thanks Scott
So it is confirmed my car came with the incorrect part. Well done P.O.
I'd still love to see a pic of the correct item if anyone has one.
Old Dec 30, 2012 | 04:55 PM
allyolds68's Avatar
This is the correct part from a file pic I have. It's not reproduced and no one has shown me a tweak yet to get something else to work. I have a complete set up and that is the only part I'm missing.
Old Dec 30, 2012 | 06:27 PM
Texas69's Avatar
Thanks for the photo. That is an odd piece, and probably difficult to fabricate
bobfo1
Jul 23, 2014 08:22 PM
rcktdoc
Apr 22, 2014 04:12 AM
firefighter5174
Dec 13, 2011 06:01 PM
ros6872
Mar 7, 2010 06:12 PM
KQQLCAT
Oct 20, 2008 07:21 AM
