Roof Rail Weatherstripping on 72 S HT ?
Old Oct 23, 2013 | 09:49 AM
Ablast's Avatar
I'm using Metro and it just doesn't seem correct. Does the windows roll up into to weatherstripping or just up against it? Any pictures of a rolled up and slightly down window would be great, thanks
Old Oct 23, 2013 | 09:53 AM
Tony72Cutlass'S''s Avatar
You probably need to adjust the alignment of the window.
I used metro and had to do the exact same thing.
Theres about 6 screws holding the window in alignment once you take off the door panel.
Check out the cutlass fischer body manual (available for free on wildaboutcars)
Sign up, and get great info.
Old Oct 23, 2013 | 10:05 AM
Ablast's Avatar
No door panels or fuzzies on yet. Maybe I'm over thinking it.
Old Oct 23, 2013 | 10:09 AM
Ablast's Avatar
Hit reply too fast. I have the manual and made plenty adjustment. The glass fits good it just doesn't look right against the seal and not up into it. Maybe I should wait till the fuzzies are on to make final adjustment
Old Oct 23, 2013 | 10:10 AM
You sure it's turned the right way? It fits in a groove.
Old Oct 23, 2013 | 10:17 AM
Ablast's Avatar
As far as I can tell there on correct. I don't think the end pins would line up if not. But I will confirm.
Old Oct 23, 2013 | 10:31 AM
The fuzzies make a HUGE difference for me
Old Oct 23, 2013 | 10:34 AM
Ablast's Avatar
Tony, which did you go with? I see so many repops out there.
Old Oct 23, 2013 | 10:37 AM
Honestly, i bought a PUI set because i'm cheap. They're not exactly the same as OEM look, but it'll have to do. My car is a driver and to save a couple bucks is always worth it for me.
Old Oct 23, 2013 | 10:44 AM
Ablast's Avatar
I hear ya! Mines a driver also nothing special.
Old Oct 23, 2013 | 10:48 AM
Either way, the only felts that install like orginals are original GM's. The other ones will have to be modified unless you luck out on a set that fits just right.
rsandhoff
Jan 18, 2015 11:19 AM
Rocketbrian
Jul 22, 2014 09:00 AM
oldcutlass
Jun 18, 2012 01:52 PM
Restoroddin
Nov 24, 2009 09:42 AM
sixty9olds
Body work
Jun 13, 2009 08:34 PM
